A
Anonymous Posted on Feb 19, 2015
How do I clear Error 6000 in ip 4970 Canon. Start and Resume light blinks.
2answers
My canon ip 2700 printer blinks both the green and orange buttons whats the problem and how can i fix it
When both the green and orange buttons are blinking on a Canon iP2700 printer, it usually indicates an error or malfunction. The number of blinks can indicate the specific issue. Here are some steps you can try to troubleshoot the problem:
  1. Turn off the printer and unplug it from the power source.
  2. Check for any paper jams or obstructions inside the printer. Remove any jammed paper or debris.
  3. Check that the ink cartridges are properly installed and seated in their slots. Replace any cartridges that are low or empty.
  4. Restart the printer and see if the error message has cleared.
If the issue persists, you may need to reset the printer. Here's how:
  1. Press and hold the Resume/Cancel button (the orange button) for 5 seconds, then release it.
  2. Press and hold the Power button (the green button) while still holding the Resume/Cancel button.
  3. Release the Resume/Cancel button, but keep holding the Power button.
  4. Press the Resume/Cancel button twice, then release the Power button.
  5. Wait for the printer to reset itself. The green power light will blink and then stop blinking.
  6. Press the Resume/Cancel button four times, then press the Power button to confirm the reset.
  7. Wait for the printer to finish its reset process and print a test page.
If none of these steps resolve the issue, it may be necessary to contact Canon customer support for further assistance or to have the printer serviced.
2helpful
THE INK ABSORVER IS FULL
Resetter canon iP 1700 and iP1300
Step 1 : Reset Hardware
  1. Turn off Canon Pixma iP1700, iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1700, iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal
Step 2 : Using software resetter
  1. Download Software Resetter for Canon Printers iP1300 dan iP1700 Software Resetter for Canon Pixma iP1300, iP1700
  2. Ekstrak/Unrar/Unzip the Software
  3. run GeneralTool.exe
  4. Select USB Port where the canon ip1300 or canon ip1700 installed.
  5. CLick Lock Release button
  6. Select EEPROM CLEAR
  7. Click Test Pattern 1 button
  8. Your Canon Pixma iP1700, iP1300 Printers should respond as normal.
Resetting Ink-Waste Ov
3helpful
How to clear a 6800 error code
It says that waste ink sponge has reached its limit.
Try the below steps.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
Now press resume button 4 times,then press the power button, if the ink smudges you have  to clean that toner sponge
2helpful
Canon eror 6000
Error 6000
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
2answers
My canon i560 had error 6000. What is?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq20
Green and orange lights flashing, saying service error 6000
read all first!
you didn't say how many blinking
and in what order so ...
First thing you need to do is print an EEPROM information page, step number 2 below.
Once you have an EEPROM print you can reset the waste ink counter, if needed, which is step number 4 below.
Service Mode: This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
With the printer powered off, hold down the "Resume Button" and press the "Power Button".
While holding down the "Power Button", release the Resume Button" and press the "Resume Button" twice in succession. Now release the "Power Button".
The indicator will blink in green and remain lit in green.
Select one of the following service mode functions by pressing the “Resume Button” the specified number of times.
1 time = Service test print.
2 times = EEPROM information print.
3 times = EEPROM initialization
4 times = Waste ink counter resetting
5 times = Destination settings
6 times = Print head deep cleaning
Then press the “Power Button” one time to perform selected function.
If you press the "Power Button" two times it will take you out of service mode.
This information is listed above in this thread and many times in other Canon threads in this forum. I simplified Canons wording so I could remember the service mode functions easier.
PIXMA IP 3000 service error 5100
I got service error 5100 after a paper jam sometimes 5 times blinking orange. in my PIXMA IP 3000
to fix it
1. Turn off printer
7. Press the Power button and the printer should turn off, if not,
8. Your printer should respond as normal..
or: and Also;
Unplug unit, hold power and reset button down then plug it in while still holding both buttons down;
Then to step 3 above.
1helpful
2answers
Canon i850, service error 6800
This error indicated that the internal printer counter for the waste ink sponge has reached its threshold. You should be able to reset this counter once without cleaning the sponge.
Do this:
3. Release RESUME
now try press resume button 4 times..after that press the power button
This should clear your error and let you resume printing. If you start getting ink smudges on the paper you will have to disassemble the printer and clean the waste toner sponge.
2helpful
3answers
SERVICE ERROR 6000
Use this:
1. Turn off printer
5. Green lights will flash and stop blinking.
7. Press the Power button and the printer should turn off, if not, press the Power button once more
48helpful
9answers
The ink absorber is full for pixma 1880
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
3helpful
CANON PRINTER PIXMA iP 8500 ERROR 300
Thanks for your posting in FixYa.
  1. Turn off printer
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Dont forget to vote me.
Regards
Ellin
k24674
ADMIN Andrew
ADMIN Andrew
