RCA Digital To Analog Passthrough Tv Converter Box Logo
A
Anonymous Posted on Feb 19, 2015
I need the setup code for RCA Model DTA800B1 converter
Model # DTA800B1 Converter Box I have searched the internet and foud many people exployting your business making it impossable to get an answer without being robbed! Please HELP me.
pulayan
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 19, 2015
pulayan
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
755
Points
Let it be. How're you?
5 Related Answers
Anonymous
  • 56 Answers
  • Posted on Jan 26, 2009
SOURCE: Remote codes for converter box
The only information i have found is that Philips codes might work , but I have the same problem needing the code for Magnavox TB100Mw9. Philips/Magnavox is the same company
freetek
Steve Allison
  • 5569 Answers
  • Posted on Feb 08, 2009
SOURCE: rca digital converter box tv codes
You need to go to the manufacturer's website for the instructions.
In addition:
I wish someone would bring a suit against any of these manufacturers using the term 'universal.'
At best, they are 'multibrand' and, with the proliferation of 'brands,' there never will be one that can rightfully claim to be 'universal.'
There may never be a code for your brand available in every remote.
ltfrc
Mike Schmidt
  • 227 Answers
  • Posted on Feb 22, 2009
SOURCE: codes for magnavox tv for rca converter box
005 007 045 049 050 054 055 064 097 098 099 153 154 160 170 174 177 181 210 230 234 252 258 259 272 274 283
Hope one of these works for you.
Anonymous
  • 2992 Answers
  • Posted on May 05, 2009
SOURCE: I have this RCA Universal remote (RCU410WMS) and I
RCA's site list codes 25 and 006 for Magnavox cable boxes. Maybe one of these will work for the converter. The RCA site has a link so you can look up codes. Click on "find your remote control codes here" and pick your model number, then the type of device you want to control. If the codes I gave don't work, maybe try some of the other brands of cable box codes. You might find one that will work.
Anonymous
  • Posted on Jun 25, 2009
SOURCE: need t.v codes for RCA DTV converter box
It's great that you want me to tell you the solution for FREE and you wnat me to pay 10.00 to get the answer- I would gladly tell the people who visit your site the answer but it just makes it look like you are actually giving the people something when you're just out for the $$$!!! Your site is a joke and is set up to look like it worth something until you get the email that tells you any answer is just 10.00 or just keep looking online and you may just find it FREE
I have an rca converter box model number DTA800B1. I unpluggd it briefly and now don't have the code toprogram it
DirectTV remote model Rc64 will control the RCA model DTA8001B1 digital receiver. Set the remote's switch to unused AV1 or AV2 position, simultaneously press and hold mute and select buttons until indicator gives a double flash and immediately enter code number 00392 after which the indicator will double flash in acceptance. Works menu and it's navigation, channel up and down, and numerical keypad.
I have a RCAmodel#DTA800B1 digital converter box, I need the 4 digit code for my One For All model#urc3021 remote control
0865,0948,0823,0432,0886 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
I have an RCA TV converter box, model DTA800B1. I don't have the box or instructions, I am attempting to conneect it to an RCA TV with a built-in DVD player. I would appreciate the code that the TV...
There are a lot of possible RCA TV codes programmed into the DTA800B1 remote.
Try the following three digit codes: RCA 000, 001, 005, 072, 073, 074, 075, 076, 077, 078, 135,
138, 140, 144, 150, 156, 159, 162, 163, 169, 171, 178, 229, 246, 249, 260, 274, 275, 293, 302 in order.
To program the remote. Turn on your TV manually and press PGM (to the left of the zero in the number pad section). The LED should light and stay lit. Type in the first 3 digit code and press OK (in the center of the arrow keys near the top). See if the gray volume up/down keys work to change the volume. If it doesn't work press PGM again and enter the next code.
Note that the converter box remote will only turn on and off, switch the input from Channel 3 or 4 to AV in, adjust the volume and mute the TV. It will not control any of the DVD functions. Your original TV remote will not control the converter box.
The manual for the DTA800B1 is available here: http://www.1800customersupport.com/productdocuments/DTA800B1_RCA.pdf .
I hope this helps.
(who has the DTA800A which is the model without the analog pass-through.)
Have an rca digital converter box model dta800b1 and a phillips universal remote can i program it so my box get the channels
Find the user guide for your universal remote and use the RCA cable tv/satellite codes, and one should work for your RCA DTA800B1 converter box. My Sharp Aquos remote liked the RCA satellite code.
1helpful
Lost codes for RCA DTA800B1 converter box
rca converter box syvania tv codes please thank you robert
55helpful
2answers
Need sanyo tv code to connect rca/dta800 converter box
sanyo 037,082.083.124.198,268.274 Press program, three number combo, ok, check volume control for function
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
