Question about Power Acoustik PTID-8970NRB 7 Single DIN Touch Screen DVD/LCD with Bluetooth, USB Mini, SD Card Slot, 3.5mm Inputs"
Ptid 8970 it says something flips down to load dvd but for the life of me i cant figure it out
  • 84 Answers
Probaly the whole face folds down check all around the edges for a release if not send me a pic
Posted on Feb 19, 2015
SOURCE:
Parking brake switch wire on a power acoustik double din
this use to be simple for most units and yes it would work, however, manufactures became wise to this idea and placed a relay inside the unit that must be reset to prevent us WISEGUYS from doing so, but i do not know if this is the case with yours, if it is then you can run a toggle switch between the unit and the ground in order to reset this relay as needed with a flip of the switch
Feb 21, 2013 | Power Acoustik PTID-6250 6.2" DOUBLE-DIN...
A freind let me borrow their hp dvd 1040e external 20x multiformat dvd writer. i can burn the music on cds fine with itunes, but i cant figure out how to use the litescribe to burn images on the tops....
You will need Nero burning software. It will after the normal burn show you a screen where you place the image you want to burn for lightscribe. Another failing with lightscribe is that you must have lightscribe discs!
Jul 09, 2011 | HP DVD1040i 20x Super Multiformat Dvd...
Cant use the USB! Says Close! nthing happens!
check the owners manual for the stereo and see what file system format you need to use on the flash drive i know i had the same problem when i changed radios worked on my old one but plugged into the new stereo wouldnt load had to unload the music and reformat the flash drive and then reload the music onto it that took care of the problem. where you have tried two different usb drives would say not likely you have bad drives
May 19, 2009 | Power Acoustik PTID-4003TV Car Video...
2 discs stuck in console
WOW!!! I am so sorry that this happened. Nintendo products are really hard to open. If you cant wedge the game out with a small screwdriver, dont worry about the game, here are the directions on opening it. Just copy and paste to word so you can see the whole thing easily.
How to open your Wii Console Step by Step Instructions
To disassemble:
  1. Flip the device upside down and remove the small silver Phillips screw. Once out, remove the battery tray from the console.
  2. Next remove the rubber foot directly above this battery tray. Also remove the three square white stickers from the bottom of the Wii. The rubber foot and the sticker are covering hidden screws. Figure 3 provides a shot of where these screws are located. NOTE
    Hiding screws under stickers and rubber pads is a common method used by electronics manufactures to help increase the aesthetics of their devices, as well as prevent people from easily locating screws and taking apart their products.
  3. Unscrew the two Triwing screws and three Phillips screws from the bottom of the Wii.
Figure 3 - Bottom Screws
  1. Flip the Wii over onto its right side. Locate and remove the two rear rubber feet and the two rectangle stickers near the faceplate.
  2. Remove the two silver Triwing screws in the holes and remove the two black Triwing screws on the faceplate (Figure 4).
Figure 4 - Left side screw locations
  1. Flip the Wii upright and carefully remove the two socket covers. They come right out with a little wiggling.
  2. Remove the three black Phillips screws from the black plate (Figure 5). Note the one closest to the faceplate is the longest and will need to go back into that hole when putting the Wii back together.
Figure 5 - Top black plate screw locations
  1. With the screws removed, carefully pull off the faceplate of the front of the Wii. You will need to disconnect the red/black wire plug from the Wii to remove the faceplate completely. Figure 6 shows what is hiding under the faceplate.
wiifig06.jpg Figure 6 - Under the Wii faceplate
  1. Remove black plate from memory/controller socket area.
Remove two silver Phillips and two silver Triwing screws from memory/controller socket area (Figure 7). wiifig07.jpg Figure 7 - Topside screw locations
Lay the Wii on left side (with the ATI and Nintendo logo facing you) and slowly work the right side cover of the console off the device.
This will take a little bit of force. If something appears to be stuck, double check to ensure you removed all the screws.
Locate and remove four screws holding DVD reader in place. Two are located in plain site in the middle of the unit. Two are located near the front of the Wii inside the DVD unit (Figure 8). wiifig08.jpg Figure 8 - The insides of the Wii
Slowly tilt the DVD player upward toward top of Wii. There are two wires that need to be disconnected before you can safely remove the DVD unit. One is a plug type of connector that only requires a little tug. The other is a circuit strip connector that requires you to lift the brown catch, which will release the pressure holding the strip in place (Figure 9). Do not break this!
May 11, 2009 | Nintendo Wii Console
Help i need a wire harness for power Acoustic dvd player
you would have to order it from poweracoustik.com. go to poweracoustik.com then go to contact and there will be a number call it an order.
Jan 24, 2009 | Power Acoustik PTID-5300 Car DVD Player
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Power Acoustik PTID-8970NRB 7 Single DIN Touch Screen DVD/LCD with Bluetooth, USB Mini, SD Card Slot, 3.5mm Inputs" Logo
95 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Dalynn Turner
Marvin
Marvin
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
