SOURCE: Lutron Dimmer Probelm
You may want to consider getting an "electronic" dimmer vs. a manual knob or slider. Consider using a Maestro (MA-600-XX where XX is the color). The Maestro fits into a decora opening so you may also want to get a new wallplate (Lutron makes these in a screwless version: CW-1-XX where XX is the color).
Hope this helps.
SOURCE: humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
SOURCE: Lutron Dimmer Not Dimming But On/Off Works
The type of track heads you are using could be creating the problem. Are the lamps Par 20, Par 30 (screw in base) or MR-16 low voltage (push in base)? If the track head has a small (2"x4") box and uses MR-16 lamps then you need to use a dimmer specifically designed for ELECTRONIC LOW VOLTAGE. Incandescent lights (screw in base) and Electronic low voltage need a different signal to dim. Using a standard dimmer for electronic low voltage will work for a while, but then either the dimmer or the fixtures will go bad. If your lamps are incandescent or halogen you may have just had a bad dimmer. (Not common for Lutron products) but the part number you list should be good for 1000watts and should not be the issue.
http://www.lutron.com/CMS400/TechInfoPage.aspx?id=25531
Please see "Dimming Basics" under the helpful information tab for a better explanations of the two different styles of dimming. Hope this helps!
SOURCE: Lutron Maestro dimmer rocker stopped working
Because the switches are relatively inexpensive, there aren't kits to repair them when they fail mechanically. Your best bet is to get an exact replacement from a Home Depot or such, turn off the breaker switch, and rewire it exactly as it was, using wire nuts and tape.
SOURCE: We don't like that the
The dimmer's performance would not be affected by removing the neon lamp. However, it will be important to snip the leads so they don't cause a short in the circuit board.
You could just use some high-temperature black paint and coat the neon lamp.
