SOURCE: cranks but engine doesn't start avital remote start
I beleive it is a pink wire for the ignition. If you can locate where it is connected this is your ignition wire. It may have worked loose under the dash.
SOURCE: avital 4100 remote start in 2000 pathfinder.
if your key has a blue square where the metal meets the plastic on the key, you will need to reprogram the data module used to bypass the theft system, or remove the spare key that is installed and have the dealer reprogram it
SOURCE: My Avital 477L remote got
Open door, turn ignition on, press and release programming switch one time, press and hold programming switch while pressing lock button on remote. You should hear a confirmation chirp from unit.
SOURCE: avital 5303 would not work after changing the battery in the remote
be sure the polarity of a battery when you fix it in the remote unit
