It is model # 3CRWE955275
1 Remove power from the Gateway.
2 Disconnect all your computers and the cable/DSL modem from the Gateway router.
3 Using a straight through Ethernet cable, connect the Ethernet Cable/DSL port on the rear of the Gateway to any one of the LAN ports.
4 Re-apply power to the Gateway. The Alert LED will flash as the Gateway starts up, and after approximately 30 seconds will start to flash more slowly (typically 2 seconds on, 2 seconds off). Once the Alert LED has started to flash slowly, remove power from the Gateway.
5 Remove the cable connecting the Cable/DSL port to the LAN port, and reconnect one of your computers to one of the Gateway LAN ports.
6 Re-apply power to the Gateway, and when the start-up sequence has completed, browse to:
http://192.168.1.1
and run the configuration wizard. You may need to restart your computer before you attempt this.
7 When the configuration wizard has completed, you may reconnect your network as it was before
Here on page 85 of the manual
3Com 3CRWE53172 User Manual Forgotten Password And Reset To Factory...
SOURCE: 4350 Small Network Access Point's web-based configuration tool
If it is trying to connect to the internet when trying to get to the tool, you have to get a direct link to the tool. You might find this on a forum somewhere. It might also help to update your firmware, this may solve your problem immediately. The only problem with routers is that they are built to connect to the internet.If you don't have the internet it is a tedious job to get access to your access points settings. Just get the link to the page and you should be able to change your settings then.
SOURCE: Intel PRO/Wireless 2011 LAN Access Point (WEAP2011EU)
Usually there is a paper clip sized hole in the back of the WAP that you insert a pin or paper clip into for 10 seconds.
SOURCE: resetting the senao eoc-3220 long range wireless access point/bridge
Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal. c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press "OK" to bring up the HyperTerminal window.
SOURCE: Repeater
That's not correct. I have the Belkin F5D7132 repeating wireless signal from Buffalo router encrypted with WEP 128 bit. The Belkin is a UNIVERSAL repeater, and should be able to repeat just about any Wifi signal. However, the "one touch" button will only work on unsecured networks, so is of limited use IMO. I had to manually configure it using the web interface, and ensure that the encryption method and key is identical to the Buffalo router I am repeating, but it does work fine.
SOURCE: Router working as Access Point, unable to access via we browser
Please try first plug out the router and plug in again then press & hold the reset button till the power led become red and release. If that doesn't work, plug out the router, pressing and holding the reset button plug in the router.
Let me know the result please.
Thanks for joining Fixya.
Have a good day.
Testimonial: "Thanks for your answer. It worked"
restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds.
You will lose all of your personal settings if you restore the factory default settings.
You might need to do this if you are unable to access the Web User Interface or have forgotten your password.
hope this helps
