Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer Logo
Rocheena Wright Posted on Feb 18, 2015
Samsung vrt nd or nb error code
Error code nd or nb read - what does that mean
sallymndr
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Feb 18, 2015
sallymndr
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
5419
Points
7
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Scott Sally Clough Davis
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jun 25, 2015
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2009
Points
6
It means it's not draining. Look at the front of the washer bottom left corner and open the little from cover and look for draining instructions to drain and clean the filter.
Samsung Laundry Dryer which is almost new. What does code 'dn' or 'ND' mean on a dryer?
Question edited for clarity. The code is 'Nd', or 'dn'? Neither seem to exist
https://applianceexpresstx.com/dryer-repair/samsung-dryer-error-codes-explained/
'D' codes
Error codes: dC, dE, dF, do, d0, 1 DC, and 1 dF
These error codes indicate a problem with the door, most commonly the door latch or the sensors. When these codes appear, it generally means you need to check your door to see if it closes properly.
More here
https://www.thespruce.com/troubleshooting-samsung-dryer-error-codes-2147296
https://www.google.com/search?q=Samsung+Laundry+Dryer+code+dn%2C+code+nd
What does error code nd mean?
Hello, Vicky -
Is your washing machine a Samsung? If so, "ND" means "No Drain."
Read the information here:
https://removeandreplace.com/2016/03/22/samsung-washing-machine-error-code-nd-what-to-check-how-to-fix/
If I am incorrect in thinking your washing machine is a Samsung, you can Edit your question and add the make and model of your machine, so I or someone else can find an owner's manual for you and check the error codes for your particular machine.
2answers
I need a Samsung Vrt steam manual. What does the error message 3E stand for on the, VRT Samsung Front Loader washing machine?
This video will help you diagnose the fault on Samsung Vrt steam 3e error codes and the video will help you solve the problem
Samsung VRT error code dc
dc means clog in the filter. look to the lower left front of the washer for the filter door. Take off the door and pull out the short hose. Empty the water from the hose, this could be lots of water be prepared. Then pull out the filter on the right by twisting counter clockwise and rinse the filter. Put it back together and the error should go away
Samsung Front Load VRT - nd error
where did you buy it from, call the store and tell them if they cannot get you the proper service to replace it
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
