Question about Mercedes-Benz 2007 S550
The fan is blowing but its only blowing cold air. no heat
I have a 05 ml350 , It blows cold air at bottom and luke warm air from vents , Can you help me answer on a fix
Posted on Jan 26, 2019
    Champion:
    New Friend:
  • 206 Answers
Check your antifreeze level. If it's too low, it won't be getting to your heater core. If your antifreeze level is fine, your heater core could be plugged. Another thing that could happen is your mixture door for the heat is not moving properly.
Posted on Feb 18, 2015
SOURCE:
I have a 2005Chrysler minivan front heat does not blow back heat blows cold cold air front doesn't blow at all what could this be
If the front heater does not blow any air suspect a defective fan motor or resistor. You can try turning the blower on and banging the underside of the passenger dash to see if it begins working again. If it does, suspect a bad fan motor. If blowing only cold air, the most common problem is a low coolant level
Jan 05, 2016 | Cars & Trucks
Why would my combo A/C - Heater unit not blow air while heating or cooling is selected but will blow air just fine when set to "fan only"?
Sounds like wiring issue to me. I've delt with units like this and there is a wire lead for fan only and a separate one to run the fan when the unit is cooling or heating. I'm only speculating here but I would bet money that this was improperly installed.
Dont get discouraged though because it sounds like its working (for the most part) if you feel up to the task find the manual and check your connections. Otherwise hire a professional.
Sep 20, 2014 | Heating & Cooling
My heat isn't working..the fan blows cold air
Depending on the year make and model, it could be a blend door problem if the heater hoses are hot.
Oct 08, 2012 | Cars & Trucks
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
Fan is blowing cold air only
good day, you may have some heating core issues, anti freeze leakage, have it checked. hope this helps, have a nice day
Feb 09, 2010 | 2007 Volkswagen Passat Sedan
No heat. Fan blows cold air.
I think u may have an air temperature control blend door problem, the door is moved by a small electric motor, it is stuck in the cold position.
May 12, 2009 | 2000 Honda Accord
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 17, 2017 | Heating & Cooling
Mercedes-Benz 2007 S550 Logo
438 people viewed this question
Top Mercedes-Benz GPS Experts
George Etukudo
George Etukudo
Andrew Taylor
Andrew Taylor
Richard Lindsey ...
Are you a Mercedes-Benz GPS Expert? Answer questions, earn points and help others
