It starts as usual but stops at the point when water should float into the washer. No error code appears on display. No sounds
SOURCE: Samsung Washing machine fault
I have foud a solution 4E error for my Samsung WD7101CKW. Water that comes inside washer is splitted in splitter with valves. One of these valves has a red label on it - this is a valve with restrictor of flow inside. This restrictor is used to limit flow speed mainly for testing purposes of pressure/water level sensor. Because of that restrictor (red cap with two holes of 0,5 mm diameter) blocked flow too much, after some time washer controller thinks that water has too low pressure.
Unplug washer, disassemble hoses from valves, disassemble valves from the washer (screwdriver needed), drill both holes in red restrictor to 1 mm (use 1 mm drill or just big needle). Assemble in reverse. Will work :)
Greetings - Thomas
Had the same problem - I posted full description in another 4E post - But my problem was a crack.split in the pipe to the sensor
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
SOURCE: Samsung P801DWNXRC Frontload washer displays E6 error code
I had the same problem. I ended up paying $300 ($100 part $200 labour) for an authorized technician to replace the control board and that fixed the problem.
SOURCE: I have a Samsung VRT front load washer, it was
First is to empty the water out. This can be done by following my (complete) general guidance notes below for checking the drain motor lint tray/filter and the motor.
'nf' means NO FEED and what happened afterward indicates that the water feed control valve is malfunctioning, initially not opening for water to be fed but then sticking open.
So follow these notes, particularly those in capital letters, to find how to empty the washer, and to check the state of the filter which is needed on a regular basis anyway ;-0)
Next will be a call to a service engineer to sort out the suspect valve.Sorry ;-0(
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
The "oL" error code in the Cabrio and Bravo washers means the motor is sensing an overload ("oL") condition. While this could indicate a problem with the motor, it usually doesn't. Most of the time, you'll see this error code when one of two things is going on:
1) There's a piece of clothing stuck between the inner basket and outer tub.
2) The tub is not floating freely, usually because it's seized to the drive shaft by rust and crudus; FYI: this condition is almost always caused by using non-HE detergent in this washer. Also, be aware that, if this is the case, it can be very difficult to remove the basket from a badly corroded drive shaft, could even be a two-man job.
Here is a video to help you get into the machine.
Keep me posted!
