SOURCE: laptop keyboard settings
is that all??your 'k' turns to '2' coz ur 'numlock' has enabled..to disabled that thing just steadily press the 'fn' icon on ur keyboard between 'ctrl' and 'windows key' and press the key that has the 'num lk' icon that were inside a box..if im not mistaken that thing is in the 'end' key..as simple as that..
SOURCE: laptop keyboard is not working correctly
Accoring to the problem you have mentioned i am sure the keys are not connected properly. The tab key is connected on the Caps lock key. Moreover make sure you press the fn key to check for any changes as it is the key which helps you toggle in Laptop
SOURCE: acer aspire 3003wcli keyboard stopped responding
You probably activated the "Num Lock" accidently. Just hold down the FN and look for the key that says "num lock" Now you should have your keyboard back and the numbers will just type when you hit the numbers key. I did this to myself yesterday!
SOURCE: the keyboard on my laptop has numbers and keys on it
It sounds like the Num Lock is on.
Depending on the make of the laptop there is a few different ways to turn it off.
Either just hit the Num Lock key and see if it goes off, hold down Fn and hit the Num Lock key or hold down the shift key and hit the Num Lock key.
Regards.
