Cooktops Logo
A
Anonymous Posted on Feb 18, 2015
What does Error code 35 on an induction cooktop mean
djbilo
Level 2:
Scholar:
  • Expert 85 Answers
  • Posted on Feb 18, 2015
djbilo
Expert
Level 2:
Scholar:
Answers
85
Questions
0
Helped
36317
Points
194
A quick web search of "Error code 35 induction cooktop" seems to indicate a possible bad control board in the unit, but you would need to get more specific about the make/model of the unit to know for sure. A Google search should help you find the answer but that seems to be the most common one and mostly relating to Kenmore units.
Smeg induction cooktop flashing E A?
Hi Ross,
The error code E A on your Smeg induction cooktop indicates a communication error between the electronics of the cooktop and the specific burner. This could be caused by a fault in the electronics of the burner, a wiring issue, or a problem with the main control board of the cooktop.
You can try to reset the cooktop by turning off the power supply to it and then turning it back on after a few minutes. If the error code persists, it is recommended to contact Smeg customer service or a certified technician for assistance in diagnosing and repairing the issue.
Thermador induction cooktop CIT304E error code U 24
Question moved form Water Heaters to Thermador Cooktop
There is an F24, but not a U24
F24 Touch input key stuck Replace power relay board, and touch panel
https://www.google.com/search?q=Thermador+induction+cooktop+error+code+U+24
Miele KM-493 induction stove. What does error E13 indicate?
  • Error code E13 error showing on display
  • What causes an E13, E 13 error code on the Induction Cooktop control panel?
  • Error code 13 on Induction Cooktop control panel
Cause:
  • Universal OFF key failure
Troubleshooting:
  1. If the controls are wet or water made contact with them, dry off the controls.
  2. Turn off then back on to reset.
  3. If the error persists, reset the unit at the circuit breaker.
  4. Turn the unit back on to see if the error code cleared.
1helpful
Prestige induction cooktop showing error E4
Good Afternoon friend, I appreciate your inquiry!
Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
What does electrolux stove induction error code E21 mean?
Did u ever find out.mine is doing the same.ive searched everywhere and can't find an answer
1helpful
GE Monogram f160 error code?
When an "F" and a number appear in the display and the cooktop beeps you have a function error code.
Touch the CONTROL LOCK pad.
Disconnect power to the cooktop and then reconnect.
If an F-code appears again, call for service.
26helpful
3answers
Whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Dec 15, 2009 • Cooktops
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
