Samsung LN40A650A LCD TV Logo
Posted on Jul 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pink and green lines and double picture on Samsung big screen tv.
  • Anonymous Nov 23, 2012
    what is main bd?
Anonymous
Level 2:
  • Expert 304 Answers
  • Posted on Jul 17, 2009
Anonymous
Expert
Level 2:
Answers
304
Questions
Helped
117971
Points
474
Replace the main bd. Have a trained Samsung tech troubleshoot to confirm.
1helpful
Double red & green lines on screen
thats a connector issue in your LCD, it might be your LCD connector have lose connections check it.
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Picture is double lined of greens and reds
You have a convergence output IC failure. You my also need a few small associated parts as well. Expect to pay $350-450 to have this fixed.
michtech
Left side of screen going yellow and pink with leters in double
The convergence modules have gone bad Along with the new parts kit are fuses, diodes, and resistors that usually fry when these modules go bad. Depending on the model, there will be two and sometimes 3 of these modules that have to be replaced. Each module has 50 pins each that have to be soldered, so unless you have experience with complicated TV repairs, the cost to do that repair may be as much as a flat screen TV of the same screen size as yours.
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
3answers
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Sony KP-57WS500
the unit needs the convergence ic's replaced and probably a couple of safety resistors.average repaire are about 300 from a tv shop
Pink picture with wavy green and blue lines
start with convergence ic's probably stk 392-130 big black chip's on an alluminum heat sink. mark ALL connections with majic marker. check for bad solder connections. for god's sake be carefull
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
