Supersonic IKONVERT Digital TV Converter Box Logo
A
Anonymous Posted on Feb 17, 2015
How to record a t.v. show
How to hook it up to t.v.
ROD GANDY
Level 3:
  • Master 1,602 Answers
  • Posted on Oct 21, 2015
ROD GANDY
Master
Level 3:
Answers
1602
Questions
0
Helped
591315
Points
4916
I connect my pc to tv and i wanr to record the show from the tv i am on pc screen i see the show but i can not record it why?
The PC connection on a TV is an input only and you cannot record to a PC using it. You would have to hook up to an output from the tv, most only have audio out for stereos, and the output audio and video would go to a converter box to put it on a coax output, then hook the coax output up to a tuner card in your computer.
Recording instructions
well if the vcr is hooked up and you can watch a show on it put in a tape that has a movie on it then press play if you can see the show take out that tape put in your blank tape find the show on your tv u wish to record press record try this before the show comes on record a little bit of a show like 30 sec or so then rewind and play back to see if it did record if it did just repete this when the show that you want to record comes on hope this is helpfull....
Vcr hooked to tv and converter box. Will not record digital chann
The vcr has to be set to channel 3 or 4. The converter box has to set to the channel you want to record the show from and left on during the time that the vcr is recording or you will get no recordings.
Humax DRT800 DVR recorder has no sound
Loss of sound is often a problem with the SCART connections. The SCART may not be pushed in securely, or if the SCART is old the pins may not be good. Check SCART is securely in, or try another SCART lead.
1helpful
AT2020 Not showing in recording software
find the drivers online then restart your computer. hook up the mic then restart again
Can't record
id get some spliters and hook it up that way or call 888-553-1555 and up grade to a dvr where you can pause record and rewind live tv. or get the home media dvr where you can record 2 shows at one while watching a 3rd and record on the hmdvr and play that same show on up to 3 other tv's
Play back up loaded files
if the name has been changed the recorder may not recognize it
Taping a show
as it is not seen from outside & can not be seen so it is not there. no there no hidden compartments now what you can do for recording is you can connect separate adaptor from market it can be connected from out side.
Top Supersonic Televison & Video Experts
NOEL
NOEL
Ngoro
SmartAviator
SmartAviator
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
