Koss KS4110 DVD Player Logo
P
Pat Hochevar Posted on Feb 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get the code for my Koss dvd player to make it a multi-region dvd player
I was told by using my remote I can convert my dvd player to be multi-region so I can play all dvd 's
Gary LiBritz
Level 2:
Champion:
  • Expert 209 Answers
  • Posted on Feb 17, 2015
Gary LiBritz
Expert
Level 2:
Champion:
Answers
209
Questions
Helped
43160
Points
347
Ask you question on Google
Ian Summerfield
Level 3:
Master:
  • Master 502 Answers
Ian Summerfield
Master
Level 3:
Master:
Answers
502
Questions
0
Helped
133869
Points
1385
Can you go into the settings menu and see if the region code is accessible?
1helpful
How do I hack my Region 1 DVD player so I can play DVDs from other regions?
Some Koss players are locked to only one region/zone so this might not work. Try this.
  1. Turn on the player (without a disc inserted)
  2. Press MENU
  3. Press 1, 6, 7, 1, 9
  4. A menu should pop up
  5. Press OK
  6. Press the button for the desired RC (0=code free)
  7. Exit menu
1helpful
4answers
I inherited a dvd player from a family friend when he died but he no longer had the book for me to code it as it is not a multi region dvd.
Could you please give me the brand and model of your unit so I can further assist you. Thank you.
2answers
Multi Region Code Support
SEE THE INSTRUCTION. GOD BLESS YOU
  • 1
    Turn on your DVD player.
  • 2
    Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
  • Sponsored Links
  • 3
    Push "Info" or "Setup" on your remote.
  • 4
    Use the remote to select the "Region" option as indicated on your TV screen.
  • 5
    Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Read more: How to Change a DVD Player to Multi Region ' eHow http://www.ehow.com/how_5121939_change-dvd-player-multi-region.html#ixzz2VzwQi6NL
12helpful
Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
moz-screenshot.jpgmoz-screenshot-1.jpgRegion
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
1helpful
Convert to o multi-region
  • Switch on and open the tray.
  • Press [SETUP] on the remote control. Setup menu will appear.
  • Highlight "PREFERENCES" and press [ENTER]
  • Press [2][5][2][3][1][5][LEFT][DOWN]
  • "Region Code: 2" will be displayed on the screen
  • Press [0] to set the player to region free (or [1-6] to set region manually)
  • Press [SETUP] to exit
I want to buy a dvd player bush modelDVD2054DIVX or a wharfedale with HD upsscaling in IRELAND and bring it to MAURITIUS.I want to know if they will play normally or there will be region code or something...
Heres the code for the bush. don't know about the other one though.
To convert this player to multi-region
1. Power off your DVD player
2. Power on your DVD player
3. Press the Open button on your remote control to open the drive tray
4. Press the 1 button on your remote control
5. Press the 0 button on your remote control
6. Press the 3 button on your remote control
7. Press the 0 button on your remote control
8. Press the 0 button on your remote control for multi-region playback
9. The onscreen display will indicate the currently selected region
10. Power off your DVD player
11. Power on your DVD player
Dvd region code
switch on.
open lid.
press STOP on remote.
enter code 2379 on remote.
region code list will appear on screen, using the UP/DOWN buttons on remote select required region (9 is multi-region).
press OK on remote.
close lid.
press STANDBY on player
OR
1. Power ON
2. Open Tray
3. on the remote use the code.
359735
4.Use region 0 to make player region FREE.
2answers
Setting region codes to code 1
*To convert this player to Multi-Region
1. Open the drive tray
2. Press the Setup button on your remote control
3. Press the buttons 1, 9 and 9, in order and one at a time on your remote control
4. Select the Region option from the menu and change to a specific region or all regions
To convert this player to Multi-Region if the above does not work
1. Press the 7 button on your remote control
2. Press the 6 button on your remote control
3. Press the Select button on your remote control
4. Highlight the Region option and press 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
5. By visiting the next page of this hidden menu, you may be able to disabled Macrovision by setting an option to 0, although this particular setting does not survive power off
6. Press the Setup button on your remote control
Done!
2helpful
Multi region for CH DVD 300
There's a tricky process to follow with the remote control to set the region code. It is: -Open the player. -Remove any DVD. -Close the player. -Power off the player. -Wait for 30+ seconds -Power on the player. -Press Menu,1,9 on the remote [this frequently takes a few tries]. -When the region screen appears, press enter to change region (Every time you press enter, the region code on the screen will increment by 1). -When the proper region code is displayed, press Return. -Open the player. -Insert DVD. -Close the player. -(Maybe just my player) If the player doesn't start the DVD, repeat Open/Close until the DVD starts. If it still doesn't start, power off for 10 minutes. Good Luck!
Top Koss Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Koss Televison and Video Expert? Answer questions, earn points and help others
