We engaged low range. Now the gear are stuck in first
SOURCE: 2000 Mercedes-Benz Mercedes Benz E320 Cdi Automatic
have yor dealer check for updated software for your transmission or engine control modules
SOURCE: My car will not Shift gears; Its stuck in first gear
hi,it seem your car is in emergency mode,you can check oil lever if deep stick is present,if not, better to bring your car to your dealer for proper diagnose,maybe erase fault only,ty
SOURCE: The manual gear shift will not move to reverse it
Some times you could get them out of park by pounding on the top of the shifter while moving it out of park at the same time. You need a new shifter assembly. If it won't come out of park, they can drag it onto a flatbed.
SOURCE: Transmission wont shift out of park
Try checking the brake light sending unit. Are your brake lights even working. Many newer vehincles will not shift out of park unless the brake pedal is depressed. However, a faulty sendind unit located on the pedal itself can keep you from moving anywhere. Just check to see if your brake lights are working to know if the sending unit is working.
SOURCE: Mercedes c class with tiptonic gearbox. It seems
It seems oil level is low in your gearbox, and it most likely leaking from adapter bushing ( where cable is connected to gearbox).
You need to replace seals or complete bushing and correct oil level.
Better if you visit your mechanic.
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Transmission not engaging in first
gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Vehicle only goes
in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park
and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
Engine will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Car stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come
out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic
transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car wont downshift
sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Transmission
will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
Auto wont shift
from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
Car Transmission
will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
Shift indicator
directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing
and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
Hard to shift gears on Manual
transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Automatic transmission shift lever
hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish
delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
