SOURCE: The power vent blower on my hot water tank will not shut off.
If the blower continues after the end of the burn cycle it is the cool the heater down. Over running would indicate a defective end cycle temp relay.
Good Luck, Phil
SOURCE: Eractic Power Vent Gas Water Heater
Th epproblem you are most likely have is from a safety called a flag switch usually located either in the blower or right past it. When you unplug and replug you reset the switch. Sequence of events.
1 fan comes on.
2 switch is made from the airflow of the fan.
3 ignitor come on
4. main gas valve opens and ignitor starts flame.
You are being stopped at step 2 when the fan does not move with the air. This shuts off and out the water heater from calling again. Find the fan switch and make sure it moves easily. They get dirty and also dry from lack of lube.
Good luck.
SOURCE: Atwood 6 gallon water heater gets warm not hot. LP
You have a cracked dip tube. Part at hd is under 10 dollars. Remove and replace via cold water inlet side top of water heater. Degree of labor skill 1-10 = 8.
Please Rate.
SOURCE: Exterior mounted Rinnai tankless water heater not
What is the outside temperature? If it it is below freezing, you might have a frozen pipe. Using a plumber torch heat up the pipe, if it works, replace the insulation using a heavier layer.
SOURCE: Our nordyne/intertherm water heater is constantly
Yes, it is a thermostat problem and most any local hardware or big box store will have the repair parts...
Electric Water Heater not Working
heatman101
