Question about Frigidaire GLTR1670A Front Load Washer
Is there a video showing how to balance front load washer or simple instructions on how to balance the tumbler as it is hammering during spin cycle
  • Official Brand Answer
  • 2,267 Answers
Thank you for your inquiry, Jay Kraemer!
From the information you have provided you would like a video on how to balance your Frigidaire frontload washer. I was unable to find any information on balancing your washer from your manufacturer. This could mean that it is not a simple DIY job. You may be able to perform a generic search online for any information except I would recommend having a professional technician out to accurately balance your washer. This will help to avoid any future issues. -Matt
Posted on Feb 20, 2015
SOURCE:
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
Coldcut
  • 1554 Answers
SOURCE: banging tumbler during spin cycle
Be certain that nothing got under the rubber skirt, pull it back and look /feel under it .
inside the tub are the large wiper arms solid and not come loose.
open the top access panel (3 screws in top rear )
and open the bottom access Panel (3 screws in bottom front)
Dissconnect power .
Look at the springs and arms that attach to the tub are they secure.
is the large stone concreate slabs secure.
move all these items and push at them all secure?
you can run it while open but the bottom has a switch on front right that has to be closed.
look watch listen.
Posted on Feb 27, 2008
localwonder
  • 6784 Answers
SOURCE: Front load Fridgidaire ftfb4000fs1 won't spin
This is a fault that resides within the motor control board. you will need to replace this failed module asap if possible. it has failed.
Posted on Jun 15, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Why Electrolux front load making knocking sounds during spin cycle. Model ewf1087
Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Electrolux EW1200i Front Load Washer /...
Final high speed spin very noisey
Something is causing the drum to be way out of balance. Does it bang and make noise when it's spinning empty? Probably not. Is something stuck on the side (inside of course) of the drum, causing it to shake when spinning? If not, a spring or shock absorber (connecting drum to sides, bottom or top of machine) has broken or come loose.
Nov 23, 2013 | Malber WD1000 Front Load Washer/Dryer
Maytag FAV6800AW have replaced clutch and cleaned under tumblers. Machine will not balance. When rotating tumblers entrie drum rotates (during cycle). I removed drum and no leakage out bottom. Does this...
Let?s see if I understand. Are you in a wash/agitate cycle when this happens? If so is the wash basket rotating Clock Wise with the tumblers rotating (washer top raised for observation)? With A Spin Only cycle selected and some clothes in the wash basket. Raise the washer top from the base and observe the wash basket rotation. The wash basket will rotate CCW the spin direction. Do the tumblers rotate while the wash basket is rotating CCW? If so the load will go off balance. What series is your machine it will be the first two digits of your Serial Number i.e. 10 through 17. Was the original clutch replaced because of severe rust of the One-Way Roller clutches/bearing in the clutch Pulley assembly? Do you have the original clutch pulley assembly? Did your machine use the upper the One-Way Roller clutches/bearing ring? Your series number will help me but if you can confirm. I?ll try to help?.Rich
Jan 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
The washer bounces during spin cycle
Front loaders don't like small loads. There's not enough clothing to settle around to balance it. Only do large loads.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
