SOURCE: Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
SOURCE: Kenmore 90 tub spins excessively clockwise during wash cycle.
Improperly installed thrust bearing kit. Too many washers cause the basket to spin during agitation.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Where is the "thrust bearing kit" and how can it be installed properly?"
SOURCE: Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
SOURCE: Washer doesn't agitate properly. clothes wrap around agitator
turn the machine over &inspect the belt.Get the make n model # of it &go to an appliance shop give them the #'s and take machine &prop it against the wall on a tilt &loosen the bolts that hold the pump on REMEMBERING where they go loook at the way the belt is positioned &put&match the new belt where it goes,its like a figure 8 around this place &around that place &carefully take the old belt off &attach it and then but the belt on the pump that u took off &take a bar &tighten the slack up on the pump.Install the boths and there u go try it and let me know. I did it once with a Maytag washer when I was 8 months pregnant and The washer is doing just fine.
