This is common. For some reason, the GMRS chargers of all brands break often. Unplug the unit. Try lightly sanding the contacts on the front cup/slot. Make certain you do not push them in too far. If you do, carefully pull them out. They should be bright. Then clean the contacts on the radio. If it still does not work, use a voltmeter and test the power is getting through to the battery from the charging cup. The voltage is DC and should read anywhere from 6-12 volts, maybe more.
Very likely bad batteries in the handhelds. Make certain they have been charged fully and try again. If not, get new batteries. Batteries go bad even not used, sitting in a box or on a shelf. 1999 are likely nicad chemistry and without a professional battery conditioner, I doubt they will take a charge. You could try to charge and dis charge them your self 10-12 times. Sometimes this will work. Fully charge the battery, put in the radio and turn it on until the radio beeps. Do not let it go dead overnight or you make the problem worse.
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
What you have been using are consumer grade walkie talkies. The rechargeable battery packs in them should last a full business day, unless you are in a high use area. This being said, it is also possible you might need to replace the rechargeable battery pack as they usually have just a one year life expectancy. As they start to fail they will go less and less time in a day.
To answer your question about a radio which will go a full business day, any of the business division Motorola handheld radios would work. Radios such as the CP110, BPR40, CP185, and CP200 are all make to go a full day and sometimes more. Their battery packs depending on chemistry would also need to be replaced every 18-24 months.
It's really hard to tell what's going on without more information, but it sounds like your two problems are really one; that is, the shutdown is due to low battery power. If you have a voltmeter you can check the charger output and the battery voltage when fully charged. My bet is that the batteries are no good, so they are not taking a full charge and are discharging rapidly. Try new batteries in one of the radios and see if that solves the problem.
Your battery is defective, needs to be replaced. Batteries need to be charged in a random pattern and need to be worn down randomly,else they develop a memory and won't fully charge.
