Unplugged the printer and replugged it in. Checked that it is connected to the computer. The green light on the plug is on.
SOURCE: new ink cartridge but not printing green on esp 5 kodak all inone
you need to use the head cleaning tool in the printer properties, youll
need to keep running it untill it runs clear and it uses alot of your
ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
SOURCE: I have plugged and unplugged and restarted the
Hi there please configar the printer & pc connectivity via Bluetooth first then go for test print. If not working then uninstall the printer driver and restart the pc and again install it. During installation open your eyes and read properly all the instruction. Let me know whats going on.
SOURCE: Kodak esp7 AIO My
Hi, If you make copy and black ink works fine, it will be software issue. if black doesn't work on copy either, then print head is dried up and need to be replaced or at least to be cleaned. You can wet paper towel with rubbing alcohol and dab the print head to see you can the ink flow again. Hope this help. Thanks
