4 and 5 are the same belt size. It will work. I am not sure about walmart, you can try. Canadian tire, again I am not sure. A local vac shop will have the belt for sure. If no local vac shop... canadian tire should be able to special order.
Do NOT use anything other than a dirt devil 4/5 belt.
We discovered we were not moving the bags in far enough to be grabbed properly. After pushing in the bag before closing the unit we found it started sealing properly. This was on an older system, so be sure the bags you're sealling are between the black rubber rectanglar sections before closing the door.
If this is for a canister, be sure the rubber around the lid is seated properly. The rubber can be removed, cleaned and wiped dry. Clean out the lid and dry it too. Reseat the rubber seal and try again... Hope this helps.
I just recently picked one up on ebay along with 8 more pads for a little of 20 dollars. You can also go to their website (sharkcompany.com) and order it there. I think it's 13 dollars. You can also order the pads there as well, I believe it's 20 for 3.
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=578564 Generic problem for all Vacuums I purchased a toastess vacuum posted by carmelwhiffe on May 07, 2008 I purchased a toastess vacuum bag sealer at Canadian Tire two months ago. I only had it about a month when the sealing wire broke. I returned it to the store and they replaced. One month later the same thing happened again, but because it is more than 30 days I can not return it to the store this time. I have misplaced my bill of sales. Where do I go from here.
Carmel Whiffen Marystown NL AOE 2M0 (709)279-3149 Hello, I’m sorry that I cannot help you with this, this particular site is for vacuum cleaners only and you may want to check with the manufacturer of the vacuum bag sealer to try to help you on this matter, or check with Canadian Tire to see if they have a phone # to the factory or manufacturer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Don – The Vac Man Go Ahead.Use Us.
