SOURCE: HELP: Onyo Remote Does Not Recognize Receiver when using Cable
Since you have the cable connected to the reciever thru the HDMI, you may have accidently changed the input source of the reciever from HDMI or digital to analog.
When you have the reciever set to listen to the cable, check the input mode and make sure it is set to use the HDMI or digital input and not the analog.
The rca jacks are analog, and they worked, so I think you have just solved your own problem without realizing it.
Let me know if this works and if so a good rating would be appreciated. Thanks and have a great day
SOURCE: No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
I have a high definition Polaroid tv which I bought in 2007. I have it connected to Dish tv. It worked fine at first. Now when I use the Dish tv remote, the television won't power up. The red light, which appears when the television is off turns blue when I attempt to turn the tv on, but the screen stays black. Why won't the television come on anymore?
SOURCE: i want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
SOURCE: i have Panasonic home theater
I have a Panasonic HT80 dvd system which plays 5 discs, bought in 2000.
If u have the same or similar he way to get the sound through the recorder is to put the audio output phono leads from the tv to the back of the dvd. On the remote (on mine) there is a button for dvd/tv/ext, oput this to tv it should allow the sound to be transferred from the tv set.
Paul 07956 150 240
SOURCE: Yamaha YHT-390 Home Theater System
Here is a link to your receiver, at the bottom there should be a download link, The receiver you listed isn't there but maybe the few that are there can help. Hope this will be some help!
http://www.yamaha.com/yec/products/productdetail.html?CNTID=567702&CTID=5000800&RLTID=1505&DETYP=RELATION
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-5230-Receivers-manual/id/319dj893/t/2/
