SOURCE: Kenwood chef A701A capacitor and other components
The 0.1 microfarad can be safely replaced with a 275 VAC 0.1mF mains capacitor. You can remove the clip that held the old electrolytic capacitor by sliding the old capacitor out and squeeezing the metal clip so that it disengages with the plastic base. The load resistor is 450 Ohm 15W or 20W wirewound. There is a 56 ohm resistor in series with the capacitor which helps smooth the speed change and reduces wear on the contacts. A 2W wirewound resistor works best. (It is worth removing the contacts and removing any pitting or carbon build up with fime emery paper). I have repaired about 20 speed controls sucessfully with these components.
SOURCE: Kenwood Chef A701A Motor
Hello graham.
yes we can supply the armature to A701
or maybe the problem is another's .. is necessary check all machine first before change the armature.
Regards
Kenwood Chef Restore
SOURCE: Circuit/wiring diagram for KENWOOD CHEF - Model A701A
Hi BGR1,
Can you also email the wiring diagram to me please. My email address is [email protected]. Thanks alot.
Bernard
