HEWLETT-PACKARD Envy 5530 built-in WiFi HP Thermal Inkjet eAll-in-One Color Printer Logo
Geoffrey Lee Cann Posted on Feb 16, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Double side printon hp5530 when default set to off
Hardware and hp software
Greg Ulan
Level 2:
Sergeant:
  • Expert 195 Answers
  • Posted on Feb 09, 2018
Greg Ulan
Expert
Level 2:
Sergeant:
Answers
195
Questions
0
Helped
42214
Points
530
Check printer settings on the printer. Also check settings in windows printer settings. Also check settings before each print good luck.
How do I scan both sides of a double sided document?
f it had before it has now
go into the printer settings and click on the scan 2 sides option and make as default
HP Deskjet F300
When you click 'print' on your computer, change the printer-settings to "double-sided" or "print on both sides", and then click OK. The printer will do the rest.
HP7130 Incompatible settings
Please , you have to download the driver for win8 ,by samply serching on google.com for example "
HP Officejet 7130 All-In-One driver for win 8
8helpful
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
We have 2 Canon ImageRunner 3320N copiers, but they are behaving differently when they are being used as a scanner. On one copier, when scanning a double sided paper it will automatically scan each side....
it is in the copier settings. one is actually set up to automaticly do doublesided copies as a default. while the other one is only set up to do singlesided copies
first while on the main copy screen change the setting how you want the copier setup ..... double sided printing, black and white, or how ever you want your defaults to be set up
then you will need to goto the additional functions button and under copy settings you will need scroll down to the second page.
there you will want to hit the standard setting button then click the store button, then click yes... now it will default to the double sided copies.....
hopefully this will fix the problem if not get back to me
2answers
Print one side only
Plz Check Duplexer Is Disable either thru Hardware or Software
Printer prints double sided only even though set for single
This is cause duplex printing option is enabled in the driver. If you have win XP, go to control panel and then printers & faxes.
Right click on your LJ P2015 printer driver and click on properties.
Click on the tab 'Advanced' and then click Printing Defaults.
Remove the check mark for 'Print on both sides' under the 'Finishing' tab.
Click Ok and Ok again.
1helpful
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Obehiaghe Adoghe
Obehiaghe Adoghe
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
