Refrigerators Logo
A
Anonymous Posted on Feb 16, 2015
Fridge/freezer normal settings - Refrigerators
Jorgie the appliance guy
Level 3:
Top Expert:
  • Refrigerators Master 5,639 Answers
  • Posted on Feb 21, 2015
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523279
Points
32630
Should be somewhere in between the middle settings the higher settings were generally made for appliances that are in high altitude and high hummidity zones geographically speaking
Frigidaire digital double door fridge freezer.
Question edited for clarity and correct spelling of maker.
All questions on Fixya need full 'make model (what it is)' please.
The start setting is always half way and with the aid of a thermometer you adjust either way to get 4'C for the fridge and -18'C for the freezer. A digital display fridge and freezer normally gives the temperature in numbers, either Centigrade or Fahrenheit.
But if the fridge isn't cooling, there is something wrong with it. When was the last time the condenser fins were vacuumed out?
Or you have a refrigerant gas leak and need a top up.
My refridgerator freezes the milk, How do i stop it from doing that? The temperature setting is in the normal range and the condensor coil is clean.
There are two setting on a fridge. One that sets the temp of the freezer and one that adjusts the temp of the fridge part. The fridge setting just adjusts the opening between the freezer and the fridge. So the fridge gets it's cool by stealing a little from the freezer. i'd get a fridge thermometer and set it it the fridge and see what the temp really is. The knobs in the fridge may not be accurate. Set the fridge and then move the thermometer over to the freezer and set that. Move back and forth until you get what you want. Usually the lower part of the fridge is a little colder then the top. However if you use the fridge a lot then every time you open the door the cold falls out and the fan will come on and start taking cold from the freezer. Another very cold spot is next to the vent where the cold air comes out from the freezer. Usually up top near the ice maker.
1helpful
2answers
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
1helpful
Kenmore Elite 18.5 cu ft fridge - heavy condensation/ice build up
mam please check the settings of the freezer and the refrigerator settings should be in normal mode and if u find it in normal mode then the problem is here the temperature controler is not responding to cutt off and cutt in the freezer so please check this operation.
I have a samsung fridge, model # rs-2545sh
check the cold for what you want but the ideal settings would be 5 for the freezer and 37 for the fridge
freezer can be really cold but the fridge if too cold will freeze vegetables and lettuce
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
