Question about Pride Celebrity X 4-Wheel Electric Scooter
Celebrity X The headlights work, but the horn does not and when you engage it to move the scooter will not move and no signs of motor clicking or engaging at all. what can be wrong?
Have checked the reset button, have checked the manual brake engage lever
    Sergeant:
  • 313 Answers
What about the batteries? How old are they? Have they ever been load tested? is the charger still plugged into the scooter.
Posted on Jun 17, 2015
SOURCE:
  • 29 Answers
SOURCE: Celebrity Pride SC440 scooter makes continuous clicking sound
the motor break assembly is going bad, if not replaced soon it will quickly draw down your batteries. smithrm70@hotmail.com
Posted on Sep 19, 2009
gewiz
  • 1367 Answers
SOURCE: Pride Celebrity 3 wheel. The free wheel lever
My Mother buggy does the same and you can damage the gearbox, so I use a elastic try down to the bumper this stops it from moving but should there be a need I can remove it.
the Freewhel mech may have come loose so check it out.
Regards
GeWiz.
Posted on Oct 12, 2009
  • 16 Answers
SOURCE: pride celebrity 4 wheel wont turn on
Hi
Please Check that your Freewheel Lever is Fully in Position as if is Slightly out of Position it will Not Work,
Gerry.
Posted on Aug 01, 2010
  • 118 Answers
SOURCE: NO DRIVE ON MY PRIDE REVO MOBILITY SCOOTER
You can try to do this with the cover off, just in case it is not seated properly and holding the lever from fully engaging. The actual swithc is a small microswitch down at the brake, and it can get dirt in it and that will stop it from working, or it may even fail, and need to be replaced. So I would:
1) try it woth the shroud off the motor using.
2) look for dirt around the switch.
3) take a paperclip and jump the scooter side of the switch to bypass the microswitch on the scooter, be careful not to short the jumper to the scooter frame.
Let me know how you make out.
Dan
Posted on Jun 11, 2012
SOURCE: will not move when scooter is engage
Is the dash board lighting up when you turn on the key? If so check the transmission dissenge lever. It's at the very back under the seat looks like a hook sticking out it needs to be pushed all the way in to engage your ******. If it's pulled out the scooter should be able to free wheel (in case you needed to push it) Hope that helps!
Posted on Aug 10, 2012
Pride celebrity x scooter flashes 6 times and s ometimes 5 times
hi, they are good readings, the brake resistance is a bit low...however does the brake click when moving the throttle lever to go forward or backwards ?
if the brake is not releasing the scooter will never move...
does the throttle lever feel loose ? you need to convince yourself that the throttle part is working correctly , if you double checked everything including the brake and connectors then we need to look at the controller ..
I do offer a free testing service...
Regards
Rob
Aug 24, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
Cant start my Celebrity X scooter. Seems to drop into free wheel on power demand.
Are there any fault codes? if so check your manual. Is the speed setting turned down low?. The click is the brake releasing so that's ok. Motor brushes may need attention.
Mar 21, 2015 | Pride Celebrity X 3 Wheel Scooter
I have a celebrity pride 3 wheel scooter and when i move lever to forward or reverse all it does is click but no movement
Have you checked the speed pot is not turned down too low?
No flash / beep codes.
I would check motor connector on drive unit, motor brushes.
May 24, 2014 | Pride Mobility Products Pride Celebrity XL...
Pride mobility scooter celebrity x flashing 5 times not working
Hi remove key put freewheel lever into drive & replace key .turn on...,... good luck.,
Nov 04, 2012 | Pride Celebrity X 3-Wheel Electric Scooter...
I have a celebrity scooter that powers up great and every thing seems to operate properly except it will not go forward or backward. It makes no sound when engaging thumb switch.
Make sure the drive lever/freewheel brake is engaged. Usually it is on the lower back bottom of the scooter or check your owner's manual.
Oct 29, 2010 | Pride Mobility Products Pride Celebrity XL...
Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Apr 22, 2010 | Pride Mobility Products Celebrity X - 3...
Sep 11, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
Pride Celebrity X 4-Wheel Electric Scooter  Logo
162 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
