Washing Machines Logo
A
Anonymous Posted on Feb 16, 2015
Washer won"t turn on outlet is working - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Tedowen
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • LG Expert 536 Answers
  • Posted on Feb 16, 2015
Tedowen
LG Expert
Level 2:
Prodigy:
Answers
536
Questions
0
Helped
264811
Points
943
If the washer won't start, the user control and display board or the main control board may be defective. The main control board failure is not common. Check other parts and causes first.
If there is power to the display and the machine wont start, check that the door is latching properly as there is a switch in the door latch that tells the control board when the door is properly closed. The switch might be faulty.
It won't turn on
check the electrical outlet and, or, the circuit breaker to your washer
Crosley CAWC529PQ1 won't turn on.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
When you push start button nothing happens
2helpful
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Machine won't turn on Hot Point washer, checked outlet ok
Have you tried to run it for a cycle? What exactly does not come on? Is the lid totally closed?
Few months old WM3987HW won't turn on - seems dead, unplugging and replugging won't work; outlet has power
Hi Rick,
I found your answer to another person's problem with the LG washer/dryer not turning on. We have the same problem. My husband found a piece of plastic near one set of the fuses that looks warped - like it got too hot. Is there any advice you can give? It's a piece next to the box by the main power cord with a metal coil.
Hi My mw512 fisher paykel washer won't Drain,how do i remove the drain pipe at bottom of tub? it won't seem to just pull off, des it need to be turned? cheers Michelle
I have a model 11, but I believe they are the same. The end at he outlet of the pump actually has tabs on it. Just twist and pull. Make sure the tabs are ligned up with the slots before you pull too hard.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
