Looking for yhe number fo the gear assembly,16/44 tooth
SOURCE: snowblower will not throw snow
If you take your time and remove the worm drive, carefully, then the order of installation is reverse for getting it back together. Remember to take your time and keep your cool and put all the parts back. If you have left over parts you did something wrong.
Also your local library may have the manual for your machine. Good luck
SOURCE: mtd snowblower yardmachine 3 hp/21"
if you are standing at the handles of the snow blower , kneel down there should be a sticker on the drive cover between the wheels , hope that helps
SOURCE: MTD Yard Machine Model: 13RL771H029 46" deck Need
May I also get the serial # to help you with your problem
SOURCE: replacing a MTD spindle assembly
Yes, most spindles come with non threaded holes. The metal is soft and you can just use regular bolts. Once you start them, they cut their own threads.
Testimonial: "Good, I was afraid I had the wrong part. Thanks for your help!"
Hi dave perin, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Post the model number and I see if I can find a source for you.
Try SearsParts Direct.com or Parts Tree Repair Clinic
