SOURCE: stove trips breaker
Begin by unplugging the pellet stove and using an extension cord, plug the pellet stove into a different circuit, with a different breaker. It is possible that the breaker itself is faulty. If you prove that the problem is in the breaker, replace it. If the new circuit also trips, then you will have to assume that the stove cord, or the stove mechanism is faulty and either repair or replace it. good luck with it. let me know.
please mark this answer as a fixya! ty.
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a
manual reset on the back of it that you have to press on firmly to
reset it. Open the side panel on the stove and find the wiring. You
will see the thermostat on the back side of the combustion chamber.
Look very closely and reset it.
good luck!
If you need further help, Iām available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I have an Afton bay pellet stove .Its about 2
Possibly the fan motor is seized. Have you had a look at it? if you do, unplug the unit and turn the squirrel cage on that fan by hand. If it does not turn than it has seized. You might be able to squirt some dry lube(silicon) into motor shaft bearings to unsieze it. Otherwise the Mfr can sell you a fan.
SOURCE: Smoky smell from Napoleon pellet stove.
it over fueling at low setting this is a comon problem and will do exsaclly what you have said
SOURCE: We have The Earth Stove
you must have an auto ignition, when you start the stove the auto ignite starts too
