SOURCE: Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: ifit treadmill will not incline but everything
You may need to calibrate the incline. Do this with the following procedure.
Safety key out
press the stop and speed up buttons at the same time while inserting the safety key. (you are now in diagnostics)
press the stop button one time only.
now press the incline up button (incline motor should start moving up)
incline will go up to the top and then all the way to the bottom. when it gets done you can remove the key. Reinsert the key and you should be operating normally.
Good luck Tim
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
SOURCE: I have a C900 nordictrack. The ifit live module
I just had the same problem. Of course tech support is closed so I sent an email. We'll see if they get it fixed tomorrow.
