Question about KLH R5100 Receiver
How do I preset fm stations on klh r5100 without remote?
Have tried hold/set button
SOURCE:
SOURCE: setting presets on KLH R3100
No, not so easy, this isn't like your average car radio, unfortunately. This was driving me nuts, too, but I finally found a manual. Hopefully you have a remote, since that is needed.
Once you are on the station you want to save, press MEMORY on the remote. MEMORY will blink on the receiver's display. While MEMORY is flashing, press the button(s) on the remote for the number you want to save the station under.
Neil
Posted on Dec 26, 2007
killer_clown
  • 86 Answers
SOURCE: klh r5100
Depending on the watts on your stereo would tell you the most, for example say its 300 watts u buy a 150 watt speaker it would blow the speaker, if you buy a 500 watt speaker your risking frying the stereo, it be best too even it out as best you can, i know that this has nothing to do with what ur asking but it would help you to save more money on buying a new speakers or receiver, now to the answer to you question, i would recommend a 12inch speaker, it would give you good sound quality
Posted on Oct 19, 2008
SOURCE: Trying to locate replacement remote for R5100
www.mrremotecontrols.com
Posted on Feb 18, 2009
  • 82 Answers
SOURCE: we need the remote control code for the KLH R5100
go to one4all.com and get the codes
Posted on Jul 09, 2009
  • 1340 Answers
SOURCE: Don't have a manual or the remote for KLH audio
There should be numbered buttons on the receiver.Set the channel to what you want to preset,then press and hold down the numbered button you want.The sound will probably go away for a couple of seconds but when it comes back on the channel is preset.If you press the band button while you're already on FM and it goes to another FM,you can also preset more channels for FM.There should only be one AM band,then it will switch back to FM.
Good luck! Greg
Posted on Aug 10, 2010
How do I manually set my radio stations to my rcart2770 reciever
1. Connect the FM antenna and the AM loopantenna at the back of the unit. Rotate the AM loop for better reception.
2. Press AM/FM.
3. Tune a station by pressing TUNER+/-repeatedly until the desired station is found.Alternatively, you can press and hold thesame buttons down for about one second toactivate the automatic search function. Inthis mode the unit will automatically tunefrequencies until it finds a station.
4. Repeat step 3 to tune to another radio station.
5. Press AM/FMto select between FM and AM.Storing Radio Stations
The unit can store up to 40 radio stations (30 preset stations for FM and 10 preset stations for AM) in its memory. You can enter every single radio station yourself or the unit can store all available radio stations automatically in ascending order
Automatic Preset Programming
1. Press AM/FM to enter the AM/FM mode.
2. Press and hold AM/FM for two seconds to start automatic preset programming.
3. Radio frequencies will be browsed and radiostations stored automatically. When all the available radio stations are stored or all 40(30 preset stations for FM and 10 preset stations for AM) memory locations are full,the auto preset programming function will stop.
Manual Preset
1. Tune to a radio station (see "Manual tuning"for details).
2. Press MEMORY. While the Program Preset number is still flashing, input your desired preset number using the numeric buttons or press CH+/-, then press MEMORY to store it.
Retrieving Preset Stations
1. Press AM/FM to enter the Tuner mode.
2. Press CH +/- to search up or down for thepreset stations or directly press the numeric buttons.
Apr 30, 2014 | Cars & Trucks
Tuner presets
manual tune to desired station, press and hold the number button you want that station asigned to, rinse,repeat
Mar 23, 2013 | KLH R5100 Receiver
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
I'm trying to change my radio station. The instructions say to push the snooze up or down arrows. But all that does is change it to one preset station to another. I don't want the preset stations.
For me with the M302 moondance system, the remote Tune + and Tune - buttons change the FM station (when the unit is set to FM as the source). Press and hold for 3 second to scan to the next clear station. The Track Forward and Track Backward switch between the presets.
If you are using the buttons on the unit, you can only search through the preset stations with the Snooze Up and Snooze Down. If you do not have the remote, you need to replace it. I believe this is the correct one: http://www.alteclansing.com/ae/restofworld/accessories-parts/wireless-remote-m302-a13547/invt/a13547/ .
I hope this helps.
(btw the manual for the M302 is available here: http://www.alteclansing.com/ae/restofworld/ipod-iphone-speakers/moondance-home-m302/invt/m302/ . Click on the icon with the down arrow.)
Nov 11, 2010 | Altec Lansing M302 moondance HOME Alarm...
Don't have a manual or the remote for KLH audio video receiver model r5100. Cannot figure out how to program the presets on the am/fm radio. Can someone tell me how or do I have to have a rermote to...
Good luck! Greg
Aug 10, 2010 | KLH R5100 Receiver
I have a new ESTR 200 that has been in a closet for a couple of years. Very little seems to function well. The presets will not hold if I turn the system off or if I turn to another function. Record...
I assume we're talking about the Element ESTR200...
A turntable will not work with this receiver unless the TT is already preamplified. No Phono Preamp in this unit.
Presets:
From the manual...
Store a station
1. Press the FM/AM button on the front panel (or
the AM/FM button on the remote).
2. Select the station you want to store in memory
by the methods described above.
3. Press the MEMORY button on the remote
While "MEMORY" is glittering, press number
buttons on the remote for the station.
If the Memory indicator on the display turns off before you preset the station selection, Press Memory again.
Manual preset
1. Select the band wave by pressing FM/AM
repeat.
2. Turn to a radio station(see "Manual tuning" on
page 8 in details).
3. Select a group (A- D) of preset stations. This
group will be displayed on the front panel.
For example: "A".
4. Press MEMORY on the remote control.
"MEMORY"will appear on the display.
5. While the word "MEM" appears, input your desired preset number (1-8 ) by using the numeric keys on the remote control to store the radio station. For example this number is "1", the station is stored as "A1".
NOTE:
A new setting can cover the former one.
This memory is kept before next reset.
Retrieving preset stations
1. Press FM/AM button on the front panel or the
remote control to select tuner mode.
2. Press A/B/C/D button on the front panel or the
remote control to select the group of preset stations that you require.
3. Press the numeric keys on the remote control to select the number of preset station that you require. Station selected is displayed on the front panel.
4. By the same way, you can select other stored
stations.
The remote control does not operate the unit.
-Another function is selected on the remote.
Press the correct function button.
-No batteries installed. Install the batteries before
using the remote.
Be sure "+" and "-" marks of each battery match the symbol on the inside of the remote battery compartment.
-The batteries are exhausted. Replace all batteries.
-The remote is not pointed at the remote control sensor on the main unit or there is an obstacle between the remote and the main unit.
-The remote control is too far away from the main
unit, move closer.
Dec 05, 2009 | Audio Players & Recorders
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
FM-stations
I figured it out!! YAY!!!!
so here is how you set the presets:
- click source until you are on the FM radio
- click down or the play/pause button... this shows the presets
- pick which present you want to set your station on by going right or left
- press and hold down or play/pause button until preset number starts flashing
- once flashing, use right and left arrows to select your station (if you wait too long it will stop flashing and you will have to start again)
- once you have gotten to your station, push down or the play/pause button one more time, and it should be set!!
hope this helps, good luck!!
christy*
Aug 02, 2008 | JVC RA-P11 Portable Audio System - Made...
Setting presets on KLH R3100
Neil
Sep 28, 2007 | KLH R3100 Receiver
KLH R5100 Receiver Logo
145 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
