Light doesn't work
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
SOURCE: GE Monogram ZISS480DMCS Ice Maker Problem
The water solenoid valve should have 120v going to it. (You will need a multimeter to chk this). You will need to also chk. for proper ground when verifying the 120v. If you get 120v on each of the pin clips, then your plug is not properly grounded, which means that you need a new ice maker circuit board. This is located in the in dispenser (front panel opens).
SOURCE: GE Monogram ziss480dmss Side-by-side refrigerator
no replace the door control bd or check for a loose or bad connection on the control bd also in an abstract sense one of the freezer door switches could be bad ones for the freezer light ones a safety for the door dispenser sys but that would be rare but possible
SOURCE: red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
SOURCE: 48" ge monogram refrigerator not staying cold
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
sfjfg
