GE 29875GE Digital Answering Machine Logo
G
Gordon Kraft Posted on Feb 15, 2015
I believe I had a brief power surge and screen shows an "8", and is completely frozen. I tried the unplugging reset procedure twice, and the "8" continues to appear. Is the unit fried, or is there ano
I unplugged the power from the machine and wall, then plugged into machine, then wall plug.
5 Related Answers
A
Anonymous
  • Posted on Sep 28, 2007
SOURCE: GE Arctica fridge PSS26LRBSS - temp control blinks '0'
set to 0 for freezer, and 37 for fridge. give it 24 hours to stablize. blinking could mean it is adjusting.
A
Anonymous
  • Posted on Oct 02, 2007
SOURCE: Calls not saved when power is disconnected
For this particular model it says that when you want to move the unit you must NEVER unplug the power cord from the BACK OF THE UNIT! Doing so erases all messages. Terrible feature. Who would have ever guessed unplugging it from the back of the unit would erase all messages! Frustrating!
Anonymous
  • Posted on Aug 31, 2008
SOURCE: Answering machine no longer works
Wow..SAME thing...this phone system has gotten to be about 10 years old and the gurus or factory service won't help you out too much because of the bell and whistles it has...and time is money eventually...keypad membranes go bad..bugs get in them...the crawlly ones...if they share the place..my "initialization" left me throwing away the headache and going to Walmart...FIX YA!!!!!
Anonymous
  • Posted on Dec 12, 2008
SOURCE: Constant number 8
I called GE. They said unplug phone lines, then unplug power source, wait 10 to 15 minutes, then reconnect in the same order. If that does not reboot the answering machine, then buy a new one.
Anonymous
  • 405 Answers
  • Posted on Dec 27, 2008
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
2answers
Fire stick is frozen
A number of scenarios may yield a frozen fire stick. And just what screen is visible during the freeze is sometimes relevant. Other than a reset procedure, you can also consider the scenarios mentioned on the following page:
Solved Amazon Fire Stick Black Screen Frozen updated 2018
Here is a discussion of the reset process:
How to Reset Your Amazon Fire TV
This generally involves pressing select and start simultaneously and after a restart, unplugging and re-pluging the power cable after a brief delay.
What can I do to reset may washing machine showing an error word of f20
F20 is a water inlet problem not sufficient water supply. Select power/cancel twice to cancel cycle unplug washer or disconnect power
Check both hot and cold are open completely
All screens a
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • 0helpful
    NO POWER
    Need to know how many times the led is blinking.
    Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
    • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
    • If the standby light begins blinking eight times, return to step 1.
    6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
    • The initial setup screen displays if the above procedures were performed correctly.
    11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
    After a brief power surge our Vingcard 2800 stopped encoding, what do I need to do to fix?
    WE HAVE POWER OUTAGE FOR 1/2 HOUR AND THEN AFTER WE TRY TO RESET OUR VINGCARD 2800 AND FOUND BLACKOUT ON SCREEN. WE CAN SEE, IF U TRY FROM ONE SIDE UNDER THE KNEE.
    How to reset canon mp258
    Reset Canon MP258 Printer procedure:
    1. Press power button / power switch
    2. Plug cable power with holding power button
    3. Press Reset button one, release power button and press reset button twice until control panel show "O".
    4. Press "+" buttom, display changing from 0 to 1
    5. Press Power Button again , Printer will be print 1 page
    6. Open printer cover
    7. Unplug power
    8. Take out cartridge 810 and 811
    9. Plug power
    10 . Press power switch
    11. Open scan cover
    12. Insert cartridge 810, 811
    1helpful
    After a power surge from lightning outside, no view screen
    if this has a battery pack try removing it then put it back in.
    Av-48p776 rear projection jvc. power surge from a lightning storm
    You will need to replace the convergence chips located inside the set. Typically a repair shop will charge 150-250 to fix it. Good luck
    1helpful
    3answers
    Doesn't boot up
    try it pluged in without the battery, does it turn on?
    when it shuts down, does the power light stay on? or is it just no display?
    Top GE Lands Phones Experts
    Grand Canyon Tech
    Grand Canyon Tech
    k24674
    Are you a GE Lands Phone Expert? Answer questions, earn points and help others
