*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main
circuit board.4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
http://www.fixya.com/support/t451942-help
THIS WORKED!!! Don't throw it out try this first for: Ink system failed Error
xc18a0101 on photosmart D7160.
This is to reset the error code only,you will need to explain in more detail why you got the code and what you've done to correct it.
