Jura Capresso 560 Electric Burr Grinder Logo
R
Ryan Posted on Feb 15, 2015
How do I remove the outer casing of the grinder?
There are no screw on the bottom of this grinder. How do I take the casing off to get to the insides?
bluegirl64
Level 1:
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 2 Answers
  • Posted on Mar 09, 2015
bluegirl64
Contributor
Level 1:
Habit-Forming:
Welcome Back:
Problem Solver:
Answers
Questions
Helped
1684
Points
I have a Bodum grinder and the screw was under one of the rubber feet. Not sure if your brand does too.
How do you remove the case of a Hamilton Beach Model No. 1 MPU meat grinder?
Would be great, if you used the manual. It is the only way to make no mistakes. You keep the meat grinder in one piece, make no accidents an have a clean and hygienic machine afterwards.
No use when I type what is in the manual, here, you have to read it anyway.
tip
Saeco Italia automatic espresso coffee machine Grinder Cleaning Instructions
Saeco Italia Grinder Cleaning Instructions
Removal
Step-1: Remove beans that are in the bean hopper without spilling them inside. (Use Vacuum).
Step-2: Remove the beans container by removing 3 phillips head screws. Remove the rubber gasket from below the hopper. At this stage the upper burr will be visible.
Step-3: Rotate counter-clockwise the outer ring of the grinder assembly (the ring has gears half way around), until the red mark is at the 9 o’clock position, looking at it from the front of the machine.
Step-4: Lift the upper burr by using the fins that are on top. Press lightly on the doser adjustment gear, to clear it from the dose adjustment gear.
Cleaning-
At this stage, the grinding chamber will be exposed. Clean out any crushed coffee in the grinder chamber and the burrs. Use Vacuum and cleaning brush.
To Re-Assemble
Step-1: With the red mark on the outer ring still at the 9 o’clock position, replace the upper burr back into the grinder. Make sure that the red line (on the upper burr) is at the 3 o’clock position. This position will align the other tabs as well. During re-installation, press slightly on the doser adjustment gear so the upper burr will clear it as it is placed back in.
Step-2: With the Upper burr in place, rotate the outer ring clockwise until it stops. The two red marks should be aligned at the 3 o’clock position underneath the doser adjustment gear.
Step-3: Replace the soft rubber gasket back on the upper burr. Use the fins to align it properly.
Step-4: Slide the doser adjustment gear toward the front of the machine until it stops.
Step-5: Before replacing the bean hopper, rotate the grinder adjustment wheel to Zero (0), and the doser adjustment wheel to Minus symbol (-). Place the bean hopper into position on the machine, slightly adjusting each adjustment wheel as you are placing it down in the machine. Once in place, fasten the bean container with the 3 screws. Test each adjustment wheel through the full range of motion. The grinder knob rotates from 0 to 18 and back, and doser knob from Minus (-) to Plus (+) and back.
Now position the grinder adjustment knob at Eight (8) and the doser adjustment knob to the halfway point between the Plus (+) and the Minus (-) marks. This will put the machine back to the factory setting.
When using for the first time after adjusting the grinder, it may take more than one grinding cycles to make the first cup of coffee.
2answers
I have taken this xbox apart once before but did not get very far. What type of tools are necessary to repair this type of Xbox 360? I would also like to update the CD/DVD drive on it. Any hints or ti
Most of this can be taken apart with a screwdriver . The case is a little tricky. You will notice from the side...where the case is split, there are tabs on the inside that you need to press. I poked a small screwdriver through the vent holes to press them and get the box apart.
2helpful
2answers
Is there a fuse inside the grinder to protect it from an electrical surge. I accidentally plugged it into a 220 volt outlet.
My MDF was built in September 1993. It has a fuse inside a black cylindrical fuse holder on the electronics board that sits aside the motor. If you have a right-angle flat blade screwdriver, you can get the fuse out without removing the motor unit from the case. I didn't have the right tool, so I ended up removing the motor/grinder unit from the case to replace the fuse. The fuse is a 2A/250V Slow Blow. I used a Buss CDC-2A to replace the factory "5TT 2A/250V" fuse.
How do I remove the cover of the black and decker angle grinder.It stopped working,I think a wire is loose inside,but i cannot get it open to see if I am right. Can anyone help? Thanks. Gerry
Hi Gerry,
The body of the grinder should be in two halves. Normally there are two or more screws holding the plastic parts together but these may be hidden behind plastic stoppers. See diagram:
http://servicenet.blackanddecker.com/Products/DetailDiagram?isId=true&productNumber=11651&selectedType=16337#
Remove the screws and it should be possible to split the case.
Hope this helps!
2helpful
I have cleaned my machine and put the grinder back inside its housing but it says the grinder is blocked and won't operate. I cannot understand where it can be blocked.
You removed the grinder? Or you removed the outer burr from the grinder? It can be tricky to get back in place with the correct lineup. If you don't do it just right, it won't sit down in place like it is supposed to. Here are the full instructions, you may just need the last little bit about lining the burr up on reassembly.
From wholelattelove website:
You do not need to clean the grinder as often as you may think. Usually we do not recommend cleaning the grinder unless there is a problem with calibration or a clog. Avoiding oily beans, flavored beans, and beans stored in the fridge or freezer will typically prevent issues.
If you do experience issues with your grinder, cleaning it is the most common solution. To clean your grinder, follow these directions:
1. Remove the water reservoir, turn off and unplug the machine.
2. Take the cover off of the bean hopper and vacuum out the beans.
3. Remove the 3 Phillips head screws that are in the bean hopper.
4. Lift up the bean hopper and set it aside.
5. Open the machine's service door and remove the drip tray and the brew group.
6. Remove the rubber gasket from the top of the grinder area.
7. The grinder is made up of 2 pieces. The inner piece has 4 tabs that the rubber gasket sits on. The outer piece has teeth in a ring on the exterior covering ½ the circumference.
8. Rotate the outer ring 180 degrees counterclockwise. You should be able to lift off the inner ring. There is a red spot on the outer collar which should now be facing the 9 0'clock position when you are at the front of the machine.
9. Vacuum out all of the beans and ground coffee.
10. If possible, use a small pipe cleaner to get grounds out of the "pathway" going to the front of the machine. It is located on the floor of the grinder at about the 5 0'clock position.
11. Above where the brew group would be located, there is a gray triangular tab attached to a door on a hinge. Pull down on the triangle - coffee grounds may come out.
12. Look above the trap door and you will see the other end of the chute. Vacuum out the chute and clean with a pipe cleaner.
Reinstalling
1. Drop the inner burr onto the grinder with the tab that has the red and blue marks facing the right hand side of the machine at approximately the three-o'clock position.
2. Rotate the outer collar so that the red mark lines up the red/blue marks on the inner burr.
3. Reinstall the rubber gasket that goes over the grinder. The slots in the gasket line up with the four tabs of the outer burr.
4. There is a straight piece located directly to the right of the grinder. This is your dosage control. There is a piece that can slide backwards and forwards on this dosage arm. Push this arm all the way to the back of the machine.
5. Set the knobs in the bean hopper to #0 on the grind setting knob. Set the doser knob all the way to the plus setting. Now place the hopper back into the machine.
Note: You may have to rotate one or both of the knobs, a small amount, to get the bean hopper to set down on its supports.
6. Install the 3 screws.
7. Replace the water reservoir.
8. Fill the bean hopper with a cup of beans.
9. Plug in and turn on the machine.
10. Reinstall the brew group and the drip tray.
11. Once the machine warms up, press the small coffee button. When the grinder comes on set the grind setting to 6.
Note: You may have to press the small coffee button twice or 3 times before the machine will make a cup of espresso.
2helpful
2answers
Machine says beans are empty and will not brew.
Try adjusting the grinder coarser when it is running. Either the grind is too fine or the grinds chamber is blocked, remove the brew unit and check the gate to the grinder on the inside right.
3helpful
Braun 5723 shaver - how to replace batteries?
Remove the two screw covers on the bottom of the shaver and then remove the screws underneath. Once screws are removed, the outer case will slide off from the bottom. You will then have access to the insides and the batteries.
You will find replacement batteries for this model at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
6helpful
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at [email protected].
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
1helpful
How do I remove the burr grinder for cleaning? Saeco Royal Exclusive
This is not a hard procedure, but you have to feel comfortable with DIY projects.
First empty the bean container. Vacuum out any remaining beans. Remove the philips screws from the hopper. Lift the hopper off. Vacuum any loose beans out. Remove the rubber gasket. You may clean this with a mild soap solution. Remove the grind adjustment lever- lift straight up with index fingers under the flange. Turn the outer ring with the holes counterclockwise, lift the center ring with the ears straight up when the outer ring is loose enough. The ring with the ears is the upper burr. Clean with a brush. Don't use water or other solutions. Vacuum the beans chamber and brush clean. Replace the upper burr ring matching the ears with the grooves. Turn the outer ring clockwise until it stops. Pull the inner ring to be sure it is locked. Now turn the outer ring back 13 clicks. Replace the rubber gasket. Replace the grinder adjustment lever- drop the lever flange inside on the outer ring with the lever grip loop over the top at #4. Press the flange with two fingers while supporting the outer ring from below. This seems tricky, but be patient. Replace the hopper and screws. Do any grinder adjustments while grinder is running with beans, it may take a few shots to be back at your preference grind! Good luck!
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
