1. installed AT0100 utility.... 2. checked network adapter is enabled and wifi connection symbol. 3.Did manual set up of wireless network. Disabled and then enabled the network again. 4. rebooted laptop 5.now gives message of limited connectivity to wireless network
If the only thing that has changed is the install of the AT0100 utility then I would un-install that utility. I'd agree that the wireless connection is sortof not the problem. The fact that can and are connected indicates that connection is being made. However, it could be an "ip" issue. If you are connecting through DHCP then your system should be able to pick up a new "ip" lease and it should connect though that could take just a little bit of time. You might go into the adapter settings and check your ipv4 settings and verify that it is selected for DHCP or an address with a correct subnet mask and Default gateway. A way to check is from the start button, type cmd and press enter. This will bring up a separate screen. At the Dos prompt type "ipconfig /all" This will give you the details of all network devices on your laptop and how they are trying to talk.
The wireless connection from the laptop is working, as it says "limited connectivity".
The problem lies with the connection to the internet from the router. Check the set-up and power reset the router to re-boot the connection to the internet.
SOURCE: Asus Eee PC wireless connection pending
You may be choosing the wrong encryption method. For instance your entering your wireless key (WEP) and you have it set on (PSA, WPA). Make sure those settings match. Also you may have an IP conflict which is resolved by setting up a static ip. If the encryption methods match and you need help with a static IP let me know
SOURCE: Asus eee pc cannot connect to home network but can to others
I am curious if our online chat solved the situation. We were disconnected before I could ask if you were able to connect. Please let me know if your issue is resolved.
Robshow
FIXYA
SOURCE: ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
SOURCE: ASUS PRO50G series laptop, wont connect to my wireless internet
pls tell me when u clik on connect wi fi what error come.
r u able to connect or not let me know please
SOURCE: Asus eee pc 900a wireless connection not working
I've experienced the same problem with my ASUS netbook. Uninstall the wireless hard - remove hardware in control panel, reboot the machine and allow it to auto find the adapter again. This should correct it. If there are still problems verify that you have the most current driver for the wireless adapter, either from Asus, or the wireless adapter chipset manufacturer (i.e. Intel, broadcomm, etc.)
If you're using a Toshiba laptop and you can't figure out how to enable WiFi you probably aren't alone. Thankfully there are several approaches you can take from a hardware and Windows Operating System stance to turn on your wireless connection while making sure you can properly connect to a wireless network.
Difficulty:
Easy
Instructions
Look at the keyboard options on your laptop. You should see a button that looks like a small antenna. The button placement may vary from device to device. For instance, you may have a dedicated button or it may be placed much like the option circled in the picture to the left of this step.
Click on the "Windows Start Button" and Navigate to "Control Panel" then click on "Network Connections" or "Network and Sharing" depending on your version of Windows.
Right-click on your wireless connection icon once the "Network Connections" window opens. Choose "Enable" and left-click on that option with your mouse. Wait for the wireless connection to enable.
Alternatively you can try clicking on the " Windows Start Button" and then clicking on "Connect to," where you will click on "Show all connections." When the connection window opens up, you should right-click on "Wireless Network Connection" and then choose "Enable." Now right-click on "Wireless network connections" and then choose "View Available Wireless Networks" to see if your WiFi adapter is enabled.
Hope this was helpfull
I would ask asus support to comment on this problem and what this utility is requied for their contact page ishttp://vip.asus.com/VIP2/Services/Questi...
