Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
A
Anonymous Posted on Feb 14, 2015
My bosch nexxt premium washer keeps getting check water tap light
Edd
Level 2:
  • Expert 145 Answers
  • Posted on Jul 12, 2015
 Edd
Expert
Level 2:
Answers
145
Questions
Helped
82403
Points
201
Blocked inlet filter or kinked hose
if not then it will be your inlet valve
5 Related Answers
Anonymous
  • 213 Answers
  • Posted on Nov 20, 2007
SOURCE: Check Water Tap??
remove the cold water hose from the washer look inside the parts of the washer you unscrewed it from, there is a plastic screen in there that needs to be clean out. you can pop it out with a small flat head screwdriver, clean it then pop it back in. also remove cold hose from valve on wall. there is another screen in there that needs to be cleaned. this will fix the problem
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 11, 2010
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Jan 23, 2010
SOURCE: NEXXT Premium will not spin or drain
There should be a filter located at the bottom right front of washer behind drop down flap or plastic cover.
Unscrew anti-clockwise to remove and clean.
Testimonial: "Thanks. Great advice. We found a sock clogging the drain."
Anonymous
  • 2605 Answers
  • Posted on Apr 06, 2010
SOURCE: Bosch Nexxt Premium WFMC6400UC washer has error
Sorry to hear you`ve been stuck so long. The first thing to do is get any water out which may still be present.
As for the problem you`ve described, typically what this really means is an obstruction/debris inside the drain pump, specifically the button trap/lint filter insert preventing the unit from spinning or draining properly.
You haven`t mentioned whether you`ve checked the pump or not, so I`ll assume you didn`t. This is how...
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
  1. Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, I can't say, I'd guess you could get wet. ( unless you`re lucky enough to be close to a floor drain )
  2. Locate the round door on the front of the machine (about 6" in diameter, lower right corner)
  3. Find a drill bit or small screwdriver that fits in the hole in the round door.
  4. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful or wear chain-mail gloves).
  5. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan ) There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out.
  6. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
  7. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
  8. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
The error code should be gone when you restart a cycle however, if the error return`s you`ll need to check further for blockages in the drain hose, or the bellows from the tub to the pump.
Ultimately you could have a faulty control, but not very likely.
Hope this help`s. Thank you for visiting "fixya", please take a moment to rate the solution provided here accordingly.
Let me know if you require further assistance. Good luck.
macmarkus :)
Testimonial: "thank you very much for the advice!!! we were able to open the washer' however the buttons are not working and the error message stays "
Anonymous
  • 2605 Answers
  • Posted on Jun 18, 2010
SOURCE: I have Bosch Nexxt Premium WFMC6400UC Front Load
Hello and welcome to fixya.
I`d suggest removing the back panel and inspecting if the belt has perhaps come off.
**Unplug the unit from the wall first**
If so, put the belt around the motor pulley and start it around the drum/drive pulley. As you hold it in place spin the large pulley and it should go back on, careful not to pinch your fingers...ouch :(
Let me know what you find out or if you require further assistance.
If this indeed solves the problem please take a second to rate my solution accordingly.
Thank you for choosing`"fixya" and good luck.
macmarkus :)
2helpful
Bosch Nexxt Premium washer shaking like crazy
Check that the w/m is level (not necessarily with a spirit, just that it doesn't rock and roll), lock the foot nuts up to the machine. Check the pump filter and outlet pipes for blockages. A machine will be noisy if it taking to long to discharge the waste water. If you have moved the w/m and are in a hard water area, you may have dislodged built up lime and that has created the problem, run a heavy duty descaler (designed for w/ms) through the w/m.
Good luck
1helpful
Bosch logixx 1400 water tap off??
try taking the screen filters out of the hose lines connecting to the faucets. Sometimes they will restrict too much or even get clogged.
3helpful
2answers
Error code 02 on a newly installed Bosch Nexxt Washing machine
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
2helpful
I get a check water tap error 2 to 4 times a load
I have this problem. This code is due to restriction of water flow. In my case, we have sand in our water, and I have installed a filter between the water line and the washer. When it gets clogged, the flow is restricted and the Check Water Tap message appears. Your washer has filters on the back of the washer itself that may be clogged and need cleaning (which is why I installed the water filter between the washer & water line to prevent it from getting into the washer filter). Your washer manual shows you how to check/clean them. Also, you may have low water pressure during summer months due to lawn watering in your area that could cause this lower water pressure.
1helpful
2answers
Washer will not spin
Carbon brushes in motor have worn down clean armture and replace brushes.
Lights went out on my bosch washer and i cant get clothes out
I unfortunately was not able to get the service manual for this machine but as far as I remember there is an internal fuse in the bosch nexxt.
Will be lokated where the power enters the machine or on the control board.
2answers
Bosch Nexxt WFMC3200UC
Bosch Nexxt WFMC3200UC Water pouring out from beneath washer. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
9helpful
2answers
Check Water Tap??
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
