How do i change my aveis tv from usb mode to tv mode without a remote?
The TV is stuck in USB mode and we lost the remote. We are trying to program a universal remote but need to be in TV mode to do so. How do we change from USB to TV mode?
    Sergeant:
  • 214 Answers
I would suggest you take that remote back. I got a cheap 8 dollar GE remote from Dollar General for 8 bucks and all that is required to program it is for the TV to be on. I've never heard of a universal remote having to be in TV mode as that would defeat the purpose.
Posted on Feb 14, 2015
SOURCE:
SOURCE: sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Posted on Mar 01, 2008
SOURCE: i cannot get to video
actually my problem is opposite it somehow got put on Video2 but I need it on Front
Posted on Sep 16, 2008
SOURCE: Durabrand TV stuck on AUX mode
You can program a Comcast remote to work with the TV. Press the "TV" button on the Comcast remote. Then, hold down the "Setup" button until the red light blinks 3 times. Enter a 5 digit code:
These are the Durabrand codes: 10171 10463 10180 10178 11034
The 10171 code worked for my Durabrand DWT1905. Then use the TV/VCR button located beneath the "7" to switch inputs.
Posted on Aug 17, 2009
  • 3 Answers
SOURCE: Lost sponge bob tv remote control
Get the RCA 4 device universal remote from radio shack. model #RCR4383N $10.00. It wouldn't work using the emerson codes in the manual. Let it find the code automatically. input button on bottom will switch to and from AV input.
Posted on Nov 16, 2009
willadavis76
SOURCE: Need code to program universal remote for my Apex LCD TV
i have apex tv 2003 and i need a code for my remote
Posted on Jun 02, 2010
Ledn49m35 hisense tv stuck on usb mode without remote how can i fix it ? help please :(
either use universal remote or buttons on side to menu and change from usb to other mode
Aug 22, 2018 | Hisense Televison & Video
My tv stuck on usb mode
power on and use the menu button. if that not work hold them both down at same time as turning on the tv.
Feb 08, 2015 | Televison & Video
How do turn my tv back to video mode so i can watch my dvd with a universal remote.
Check your universal remote for a TV-DVD or SOURCE or INPUT button and try that.
Dec 25, 2014 | Funai 24ME403V 24" 720p LED-LCD TV - 16:9...
How to return from usb mode to tv mode without remote control for sinotech LCD tv manual
No other way. You should have its remote control to select inputs. I thinks that I've answered this problem, many times before.
If you post any more, please provide the name of yours with the post, so that I do recognize you and not to respond it, and allow any other to answer you.
Here I see this problem is posted by some 'Anonymous" person.
Whatever it may be, you can't select the input to your Sinotech TV; without its remote control.
Aug 13, 2014 | Televison & Video
Need remote code for Aveis tv
036,018,022,038,071. Check these codes. If you wish to get more codes, check this link.
Feb 27, 2013 | Televison & Video
My AVEiS 26" TV has
Your TV needs software upgrade. If you have usb port on this. Check the manufacturer's website for the TV softwar, download it. Copy it on pen-drive. Plug into usb port & follow the procedure as per the user manual to upgrade the software.
If the problem is not solved, then it needs repairs in its analog switching section.
sonsunny
Jun 17, 2011 | Televison & Video
Tv is stock on tv mode. How to change to game mode?
You need the remote to change to game mode. The original remote doesn't appear to be available. A substitute remote with the function is here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DWT2405&uuid=12931247714820 . The Game button switches to and from game mode. Other universal remotes may work but a source or input button is needed. Then try various codes for either Durabrand or Funai TVs (Funai built the TV). The other issue is that the remote needs to have been programmed at least 6 months after the TV was released. The remotes that are programmed via a USB connection to a computer will definately be able to match the function.
I hope this helps.
Dec 23, 2010 | Durabrand DWT2405 24" TV
My tv will work on game systems but will not change channels with the remote it is stuck on video 2
You need to change the input source to TV. You can do this with the original remote by pressing Input. (Unless the unit is in VCR mode then press TV and then Input). There is no Input button on this TV as far as I know.
If you do not have the original remote, you need a remote that matches this function. An exact replacement remote is available here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=DS35510&uuid=12925568663700 . Some universal remotes will have this feature but usually not the cheapest ones. Make sure the universal remote was programmed at least 6 months after the TV was released. The exception: the universal remotes that can be programmed via a USB connection to your computer.
I hope this helps.
Dec 17, 2010 | Sanyo DS35510 35" TV
Need a code for an Atlas PVR universal remote control on a 32 in. Aveis flat sreen tv or to know who makes Aveis tv. Thank you!
Aveis is a daytek product which is a Daewoo company. I found a site where you can check and make sure of this http://www.daytek.ca/ Click on products. I found codes for daewoo on page 35 of a manual I downloaded from this site:http: //tv.manualsonline.com/manuals/mfg/shaw/atlas_pvr_universal_remote_control.html . I hope this works for you.
Oct 06, 2010 | RCA Universal Remote Control
TV Stuck in VCR mode
I used code 191 for my combo unit
Jul 09, 2008 | Daewoo GB-20H4T2 20 in. TV/VCR Combo
Televison & Video Logo
206 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
