COBY-PERSONAL & PORTABLE Coby Mp620 4 Gb Red Flash Portable Media Player. 1.8in 4g Video Mp3 Player Mulply. Audio Player, Video Player, Photo Viewer, Fm Tuner - 1.8 Active Matrix Tft Color Lcd - 12 Hour Audio Logo
A
Anonymous Posted on Feb 14, 2015
How do I copy mp4 files to coby mp625 - COBY-PERSONAL & PORTABLE Coby Mp620 4 Gb Red Flash Portable Media Player. 1.8in 4g Video Mp3 Player Mulply. Audio Player, Video Player, Photo Viewer, Fm Tuner - 1.8 Active Matrix Tft Color Lcd - 12 Hour Audio
Chris Hunt
Level 3:
Genius:
  • Master 1,342 Answers
  • Posted on Feb 14, 2015
Chris Hunt
Master
Level 3:
Genius:
Answers
1342
Questions
0
Helped
176983
Points
4674
I use the USB cable to connect my laptop to the tablet. Then find the correct music folder and drag them over.
How do i get music on my coby mp625-4g
Use Windows Media Player the sync option
tip
COBY MP-610 File System Error
COBY MP-610 Digital Media Player File System Error Solution
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the archive from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
2answers
Need to download manual for coby mp601-2g
You can download a copy of the manual from the manufacturer's web site at
http://www.cobyusa.com/files/manuals/MP601_MN.pdf
I cannot put video in my coby mp4 player my coby mp4 model is MP601-4G
Hi!
Your player supports only the MTV video file type...
To convert your videos to the MTV file type, use MTV Video Converter OR the bundled Coby Media Manager (CMM) software (if you don't have it, download it from here)!
Detailed instructions on installation/usage of CMM are found on the User's Guide...
If you are satisfied, rate my solution with 4 "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
3answers
My Coby mp601 8gb won't play the converted mtv videos, says "format not recognized", what's up with that???
Check the specification of your MP3 player to determine thetype of video file format it uses. Most common video files that MP3 players use are, AVI andWMV, there may be others such as FLV, MOV and DivX. If your player cannot play a video then it is anincompatible video file format, then you need to convert that video file to aformat that your MP3 player uses. Click on this link for instructions on converting videofiles for MP3 players :- http://www.fixya.com/support/r5874192-play_videos_mp3_player
4helpful
6answers
How can I get my player to show video? It always says invalid format.
Video Format Support MTV
You need a mtv converter ...after you convert your video files from .avi ,mpeg,or any other format...transfer the converted files to your coby player
MTV converter free download .
3helpful
2answers
I have copied several videos to my mp600 but I can`t see them. Do I need a special software? Where I can download it?
Coby's can only play videos in .MTV format (nothing to do with the cable channel that use to show music videos). So if you copy .WMV, .MP4, .RM, .MOV, they will not play.
There are some program that I had not used on the Internet that can convert video files to .MTV format. Do a search through a search engine for them
Good luck.
3answers
What file format should the videos be?
try converting it to mpeg using a video converter program.
How do i fix a coby mp4 file system error
reset ur phone........if it won't work then u might b using MP4 file of different type which is not supporting ur phone
Top COBY-PERSONAL & PORTABLE Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a COBY-PERSONAL & PORTABLE Audio Player and Recorder Expert? Answer questions, earn points and help others
