F10 error
Good Morning mark, thank you for your post!
Based off the information you have provided your Frigidaire range is displaying an error code of "F10". An "F10" error code normally stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to experience an issue with the "F10" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. This will help you avoid any unnecessary part purchases. Hopefully this information has been helpful. -Matt
SOURCE: F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks
Good Luck
Appreciate to rate as "Fixya"
SOURCE: I have a run away temp on my fridgeair range oven
Might be the Eoc but most likely its the thermostat / thermal couple!
SOURCE: F10 lights on at the
Open the bottom pan drawer, the number is on the leg.
Testimonial: "Thanks you! Now I can order it,"
