Jawbone UP24 Wristband Medium Logo
c
carol walsh Posted on Feb 14, 2015
A friend just gave me their jawbone up 24. How do I set it up? I have iphone 6 plus. The jawbone up 24 is charged now, but for whatever reason it's not pairing with my iphone 6 plus.
1. band is used from a friend, it's charged 2. my iphone 6 plus has up app with bluetooth on 3. jawbone and iphone won't pair
How to factory reset iphone 4 withouw icloud password?
It's quite easy. You can resort to iTunes to reach this aim. Just follow below steps.
iTunes enables you to restore iPhone 6 Plus to factory settings. Before you start restoring iPhone to factory settings, please note that you need to install the latest version of iTunes on your PC or MAC. Then go to Settings > iCloud to turn off Find My iPhone. Now, you can factory reset your iPhone 6 Plus with iTunes as follows.
1. Plug iPhone 6 Plus into the computer with the USB cable. The iTunes on your computer will automatically launch. If not, double-click the icon to start it.
2. Click the name of your iPhone 6 Plus at the upper right corner of iTunes, and then the information of your iPhone 6 Plus will be shown. Click the "Restore iPhone" button in the window to start.
3. iTunes will ask whether you want to back up iPhone 6 Plus before restoring. You'd better choose "Yes" for the reset will erase the contents in your iPhone 6 Plus. Then iTunes will start restoring your iPhone 6 Plus to factory settings.
3. Click Restore again to confirm. Then iTunes erases your iPhone 6 Plus and installs the latest iOS software. After you restore your iPhone 6 Plus to factory settings, it will restart. Now you can set it up as new.
For more methods, check: How to Restore iPhone 6 Plus to Factory Settings
How do I reset iPhone 4s data setting for at&t?
If you want to reset iPhone data settings, there are several different ways you to follow. I will show you one of them.
For more methods, check: How to Restore iPhone to Factory Settings
Jawbone won't pair with iphone
Hi, you need to plug the jawbone to a computer in order to connect it for the first time to your phone, it can also be an issue with your phone bluetooth, restart might solve it.
How to resert iphone
You can resort to iTunes to reset your iPhone with ease. Just follow below detailed steps.
restore-iphone-rcarq2zhug2hmvq3p5tn22ku-4-0.jpg For more details, check: How to Restore iPhone 6 Plus to Factory Settings
8helpful
My Jawbone headset will not pair with the iphone 3g, even after going to settings-general-bluetooth. The iphone keeps serching for a device but cannot find it.
1. Settings
2. Bluetooth
3. Turn Bluetooth ON
4. Make sure your Jawbone is OFF
5. Press TOP Of Jawbone & MIDDLE of Jawbone TOGETHER Until It Flashes Red & White
6. JAWBONE Will Come Up On The iPhone
7. Pir The Device With iPhone
8. Enter Four Digit Code
9. 0000
10 HEY PRESTO....YOUR PAIRED!!!!
Thanks to Sally Jo for this tip!
12helpful
3answers
Jawbone bluetooth does not charge
My jawbone was not charging at all, but then I looked at the prongs on the charger and I saw that one of them was shorter than the others, so I got a pair of small needle nose pliers and gently pulled on it. It returned to its normal length and I plugged it up. It is now charging normally.
Jawbone should design a better charging system.
Dec 14, 2008 • Cell Phones
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Top Jawbone Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
john h
Are you a Jawbone Exercise and Fitnes Expert? Answer questions, earn points and help others
