Hydrofarm Flco95w Grow Light System Logo
Posted on Jul 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Grow lights don't come on
I have my tomato grow lights on a timer and the timer isn't coming on
Craig Butler
Level 3:
President:
  • Master 1,730 Answers
  • Posted on Jul 07, 2009
Craig Butler
Master
Level 3:
President:
Answers
1730
Questions
0
Helped
697288
Points
4778
Check out the power to the timer
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
How do I choose LED grow light?
Choosing the right LED to grow light can be tricky. There are many factors to consider, such as the size of your grow area, the type of plants you are growing, and your budget. This article will help you choose the right LED to grow light for your needs. The first question you should ask yourself is, "What type of plants do I want to grow?"
You will need a different light for growing herbs than you would need for growing cannabis or lettuce. A simple way to approach this is to think about what your needs are in terms of a grow light. If you're growing cannabis, you want a light that has high lumens and a good color spectrum for the plant. If you're growing vegetables, you want a light that has high lumens and a good color spectrum for the plant.
If you're growing cannabis, you want a light that has high lumens and a good color spectrum for the plant. If you're growing cannabis, you want a light that has high lumens and a good color spectrum for the plant.
Oct 26, 2022 • Garden
Tomatoes are popular in South Africa.We can grow tomatoes the whole year round owing to our warm climate. Tomatoes need alot of warmth and light to grow well. What is the hypothesis here plz help???
They also need feeding on a regular basis.also need to have excess growth removed , this does depend on the type of tomatoes you grow.
I have my tomato plants planted in pots on my patio and the plants don't look like they are growing and the leaves are small and the edges are curling up and are dark in color. What can I do?
you need to give them more room,grow bag is needed when you water use warm water or rain waterrain is best if not warm water grow bag will help if the plant is say 2 inch in a 4ins pot it will take time to grow put 4 or 5 in a big grow bag it will need light and heat don't put in pots
Jun 16, 2017 • Garden
2answers
Facebook customer service
You need to contact Zynga support as it's a Zynga game, do this via https://www.zyngaplayersupport.com/ click your game; then on right hand side there's a red "?Get Help" click on this then either mail them or use chat.
2answers
Can I grow vegetables in a greenhouse in the winter?
You can, but they can be a little challenging because they need specific temerpatures and more sunlight than there is naturally in the winter.
Jan 26, 2014 • Garden
1helpful
My tomatoes are splitting and have rings on skin
Not a router related question, but I grow tomatoes as well. It happens when the tomato develops from the flower on the plant. It is a natural process which factory grown (and tasteless) tomatoes generally do not feature. As the tomato expands, due to plentiful water, the skin might not grow as fast since it needs an adequate amount of sunlight to both help the tomato's skin to develop and to eventually turn red. it is very common but sometimes if the tomatoes are left on the plant too long, those rings tend to split open, even if you think the tomato is still too small to be harvested. once tomatoes are nice and red, pick them rather than waiting for them to get bigger, because they will bust at their seams. You can even pick partially red tomatoes and let them sit on the window sill in the sun to have them compturn red.....now about the router issue.....
Aug 28, 2013 • Cooking
3helpful
2answers
What is the best grow lights to grow *********
That depends on what you're trying to grow and what phase the plant is in. Certain plants are adapted to grow in the shade or in warm, sunny environments. Depending on the plant, one type of light may work better than another. For example, if your plant needs a shadier environment, then a regular incandescent bulb may work best.
The other factor that goes into choosing the right grow light is what phase your plant is at. For example, a high-pressure sodium bulb may be best when your plant is in the flowering or fruiting stage.
Personally, I love using LED grow lights. Modern LED bulbs are more energy-efficient (they produce more light with less power), so they cost less in the long run. They also produce less heat, which means you don't have to worry about a ventilation system. Plus, they emit light wavelengths that correspond to the peak absorption peaks for most plants.
When choosing your bulb, you should look at the requirements of the plant and how those requirements change as the plant continues to grow. Keep in mind that the larger your plant gets, the more light it will need, so plan ahead.
Top Hydrofarm Garden Experts
Jay Finke
Jay Finke
john h
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
