Question about Hoisting
Hoist winch will pay out but not hoist in
Tried the slack wire over ride still not hoist in
What belt is strong enough to pull approximately 250lbs on a Honda 4 stroke motor?
Hi, Jay the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Good luck and have a wonderful day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 17, 2017 | Honda Motorcycles
John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
Nov 15, 2015 | John Deere Garden
Having trouble with my logging winch constantly pulling in.
service the clutch section of the winch as it appears that something is broken in that section of the winch
This situation is dangerous because if something happens, the winch cannot be disconnected or reversed immediately
May 25, 2015 | Cars & Trucks
I inserted tire tool into the guide tube and turned it but the tire would not winch down. Used a flash light, and saw that the guide tube that connects to the hoist mechanism was detached. I was able to...
You need the head mechanism in order to turn the winch to let the tire down. Its usually a hollow square head without knowing the make and model of your vehicle.
Mar 20, 2015 | Cars & Trucks
KFI winch won't spool in or out there is power to it I can hear it clicking
If your wiring a remote control to the winch or inside control,,, 4 solinoids type,,make sure the solinoids have ground on the brown wire(warn)...if you don't have a ground all it will do is click,,,even if power is applyed
Feb 19, 2015 | Cars & Trucks
My winch don't move it all?
if you can use the winch manually by pressing buttons on the winch then the problem will be in either the remote unit(Battery in back to front) or the receiver in the winch
Dec 22, 2014 | Cars & Trucks
I pinched my remote plugin cable and broke one wire. I spliced the wire and the winch still won't work. Is there a reset button or a fuse which may have shorted out? The winch is a m12000 from 1997.
Is the hot wire connected directly to the battery? Did you check to see if the wire is hot after you spliced it? There may be fusible link in the wiring or the wiring may be broken somewhere else. You can also try running a new hot wire from the battery to rule out a faulty winch. Trace the wire from the winch to its source of power, ie fuse box or battery
Aug 03, 2014 | 265072 M12000 Self-Recovery Winch -...
Warn winch troubleshooting
It sounds like your solenoid is not reversing the polarity , which will require a new winch solenoid. Before replacing the solenoid, check your switch. It might have one contact no good. Switch the wires around and try to retract winch by paying out.
Aug 03, 2014 | Warn Industries Warn 64851 Atv Winch Mini...
Wire a winch
The 1585202 winch is capable of pulling 8500 pounds when provided adequate DC power. With no load (winding up slack the cable) the motor requires 84 amps and winds at 18 feet / second. When fully loaded (8500 pounds), the motor requires in excess of 320 amps and winds at 3.5 feet / second. That's an awfully large amount of current and it will need heavy duty power supply cables to work without overheating or melting insulation. I suspect your 1585200 is the same model with same electrical requirements, but did not include a fairlead, mounting plate, etc..
Superwinch has wiring kit #2007 for front mount (5 foot cables) and #2008 for trailer mounts (25 foot cables) and can simplify the installation with other accessories as well. They're a U.S. company and can be contacted them directly:
Superwinch, LLC
359 Lake Road
Dayville, CT 06241 US
Ph: 860-928-7787
F: 860-928-1143
www.superwinch.com
Dec 22, 2011 | Electric Superwinch 12 Volt DC Winch -...
How to restring hills hoist
I'm just doing mine right now. What follows refers to the earlier folding hoist model Rotary 42, not the fixed wire line models, or the current Hills folding hoists with this type line anchor
http://www.breezedryer.com/index.php?p=product&id=791
I found that Hills don't sell new line direct, so I got some poly core line from Mitre 10, 60m for $30.
Study how the original line was strung through the clips and how it was tied at each end, and you will find that you have to remove 4 plastic wedges which secure the line in the end caps, these things
http://www.breezedryer.com/index.php?p=product&id=792
The wedge is not shown. You just push it out upwards. Then cut away and pull out the old line from all the clips, these things
http://www.breezedryer.com/index.php?p=product&id=741
Then tie the line onto one end cap as it was before, and restring the whole hoist. To get the line into the clips, you can carefully lever a bit with a screwdriver.
Don't worry too much about tension yet, just leave the line a bit slack on each run. You will have to pass the coil of line over the top of the arms many times. Finally cut it off after the final run, leaving enough line hanging down to secure the arms in a bunch when the hoist is folded up.
Make the final knot as it was, and then, without skewing the arms sideways, remove any slack going around and outwards, and finally pull in and tighten the final knot at the outer end, and replace the 4 wedges.
The line will stretch, so you may need this final step once more.
Sep 11, 2011 | Husqvarna 28cc Gas Line Trimmer
Hoisting Logo
979 people viewed this question
Top Hoisting Experts
AZBen
AZBen
Andrew Taylor
Andrew Taylor
Pierre Laplante
Are you a Hoisting Expert? Answer questions, earn points and help others
