Epson WorkForce WF-3520 All-in-One Inkjet Printer, 5760x1440 Optimized dpi Resolution, 15 ISO ppm Black / 9.3 ISO ppm Color Print Speed, USB 2.0 Interface Logo
A
Anonymous Posted on Feb 14, 2015
CHANGE INK CATRIDGE
CANT REMOVE CARTRIDGE
drvalentine
Level 3:
Master:
  • Master 876 Answers
  • Posted on Feb 14, 2015
drvalentine
Master
Level 3:
Master:
Answers
876
Questions
0
Helped
254921
Points
4299
Canon pixma ip1300 cant detect ink cartridges
remove all the cartridges. using tissue or cotton cloth.. dub the connectors to the cartridge of the printer.. then wipe the cartridge connector area dry. if this does not work, you need new cartridges. with new cartridges and the same problem persist, your printer has the problem on the in decoder strip. area. hope to be of help.
I put a yellow ink cartridge in printer and it is new but the printer is saying yellow cartridge is empty so i am unable to print anything what do i do
Did you remove the plastic Seal undernith your ink Catridge, also check for any dry ink deposites where the yellow catridge sits in the catridge carriage box, if present use an alcohol cleaning pad to clean the carriage and re-install and verify.
6helpful
Problem with ink jet catridge
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
it also can be the defective cartridge itself causing such problem..!!
well if u r a professional then just dip a cotton into isopropyl alcohol n gently rub the connector sensor/ contact surface, n reinsert it properly, gently rub on the head too n make sure ink is coming/flowing, make sure the toner is not jammed or dried up, also have a glance on the 'carriage' n see that no sensor pins are broken and or bend..!!
..if u r not an professional, make sure it is properly inserted and the ink-spill protective/head covering is removed..
if all the above fails, then it may b a defective or demo cartridge..!!
and call ur system admin....
Printer always says "Remove and check color cartridge"
It must be your ruined catridge. Some times the wire connections are burned at the side of the catridge and you must thaw away it and buy a new color catridge.
2answers
I cant print it is showing e5 on printer screen
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-3
Gettng a message that open the sticker of the catridge i the ink
The sticker is situated below the cartridge where u have the cartridge nozel.
29helpful
2answers
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Cartridge problem
Please remove the printer catridge and clean the the extra ink in the catridge holder and in the catridge connection point with the soft cloth without damaging the cables in the catridge and the holder then test it
T.Boopathy
Epsonc43sx problem
u just do a thing.just press the paper load button when the printer in power on that time the catridge will move suddently remove the ac power pin of the printerr while the catridge tray on centre afterwards u can remove the catridge and install new one
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
