First-Class SWF Converter for Google Nexus One,Convert SWF to Nexus One
Speaking of
Google Nexus One, we will immediately say it is Google's flagship smartphone manufactured by Taiwan's HTC Corporation. It became available on January 5, 2010 and uses the Android open source mobile operating system. As a multimedia-enabled smartphone, Nexus One is capable of playing videos encoded by H.263 (encode and decode), MPEG-4 SP (encode and decode), H.264 AVC (decode), audio formats including AAC, MP3, MIDI and WAV.
Personally, I bought a brand-new Nexus One when it initially launched on the mobile market, because of its 3.7 inch wide touchscreen, 5 megapixel camera and its long battery life. I am a movie fans and I always pay much attention to the newly-released movies such as Avatar, Transformers 3, District 9, and etc. So I often need a Blu-ray Ripper or Video Converter to convert these movies to my Nexus One for enjoying when traveling. Recently, I got a bunch of SWF files from my boss and wanna merge and convert these files to my Nexus One for playback. By searching the keywords "
SWF to Android Converter" through Google, I got a fabulous
SWF to Nexus One Converter. With it, I import SWF to Google Nexus One (.mp4) with success.
The Detailed Tutorial I use is as below: To begin with,
free download Aunsoft SWF Converter and install it on your PC.
Second, import SWF files to this program and specify the output format workable to Nexus One.
Expand the drop-down menu of Profile, locate and choose Android ->
Google Nexus One MPEG-4 (.mp4).
By the way, you may notice the button "Settings", this button is used to set the video and audio parameters, including Codec, Bitrate, Frame rate and Channels. As Nexus One can play movies up to 800x480 pixels, under this option, you can set video codec to mpeg4 or xvid. You can set frame size to 800x480, 480 x320 and 720 x480.
Next, if you want to join SWF files into one, you are allowed to check the box "
Merge into One to file" on the main interface.
Fourth, specify the destination folder by using "Export To" as you wish.
Last, after the settings above are done, it is time to start the
SWF conversion to Nexus One for your entertainment yourself or with your families.
Cameras are not supposed to go into pockets in your jeans. They come with a protective case for a reason. If you have the skills, the tools and the alignment facilities, you can replace the screen yourself - if you can get a screen.
