Question about Korg Pa-50SD Professional Arranger
Few button problems
Buttons not function...
CHILD LOCK ON IMPERIAL TELEVISION
problem should be solved by holding down the music button on the remote for a few seconds/not all tvs have a music button function on the remote/i would recommend that u try holding down any one of the other odd buttons on the remote for a few seconds/one of them should work.
Oct 12, 2013 | Televison & Video
Remote control problem pioneer dv-f727
A few thoughts.
1. The remote was water/liquid damaged and the buttons no loger make contact with the silicon board to send a signal.
2. Low battery??
3. If you are using a universal remote, you may have found a code that only partially functions. Keep going through the codes until you find one that fully functions.
Hope this helps!
Jun 26, 2012 | Pioneer DV-F727 DVD Player
Cobra MicroTalk. Model No. PR155. Will not turn on. No problem with the battery.
Here is the deal people! Easy fix. When you depress the on/off button on the walkies, keep the button depressed for 3 or 4 seconds. It will power up. The reason why you have to depress the button for a few seconds is because the button has more than one function. Hope this is the solution.
Jan 29, 2011 | Cobra Radio Communications
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
Only a couple of the program/adjustment buttons on my Pro-Form 930i treadmill work. Sometimes I can push random buttons and the rest of the buttons start working for a few minutes, then after a few minutes...
It sounds like either the function pad or the upper electronics is starting to fail. Also it maybe a loose connection between the function pad and upper electronics remove the upper console and inspect the connections. If you need to replace the parts sometimes with Icon products they are either separate items or they are one complete unit, you will have to call them @ 1-800-999-3756.
Jun 10, 2010 | Proform Exercise & Fitness
My asus laptop cant turn on
you need to replace the Power button...
Apr 12, 2009 | ASUS AC Adapter- Universal Notebook AC...
Ti 89 buttons won't work
Well, I just waited a few more days and now it works! I'm so happy...
Jan 14, 2009 | Texas Instruments TI-89 Calculator
Few Keys not working
this is what i did when it happened to mine. take your sim card out. put someone else's sim card in. see if it solves the problem. i know its the keys not the sim card. but it was the same problem wiht mine. the 1 button was doing the function of the star button adn 4 was the menu button.
Aug 27, 2008 | Nokia 3230
OSD Lock Problem
I have a hanns g 22" widepanel , I had the same problem with lockout. I had my monitor disc and looked on it, or in a manual if you still have it. Here is the combination I had to press and it worked. I pressed the arrow buttons and the menu button all together a few times and it unlocked. Try that!
Function Key Lock:
Press the <「Volume -」, >「Volume +」and the 「Menu」buttons simultaneously to
enable the Function Key Lock. When the Function Key Lock is enabled, only the Power
button is active. Press the <「Volume -」, >「Volume +」and the 「Menu」buttons
simultaneously again to unlock the function keys.
Aug 03, 2008 | Hannspree HW191D LCD Monitor
Korg Pa-50SD Professional Arranger Logo
440 people viewed this question
Top Korg Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Korg Audio Player and Recorder Expert? Answer questions, earn points and help others
