Question about Samsung CLX 3160fn All-In-One Printer
Paper jam My Samsung CLX-3160FN shows "paper jam" but in fact there is none. I was told by someone it may be sensor probolem, but I don't know what to do about it. My warranty expired and Samsung refused to do anything. Can I buy sensor somewhere and replace by myself? Thanks
  • 1 more comment
  • xcgroup Jul 08, 2009
    no I have done that many times and it doesn't work. The point is: it is not a problem of paper jam. The issue incurs when paper cannot roll up for print.
  • orangemek May 11, 2010
    Resetting the printer normally works, have you attempted that? You can normally get the printer to reset by holding down the power button for a few seconds.
  • paulrandolfi
    paulrandolfi Feb 03, 2013
    Paper Jam 0 will be incorrect paper setting paper over 80g select thick paper from the menu as they get older they need a higher setting when new 70 g and over
  • 192 Answers
Probley not but i think you may be able to extend you warantee if they will let you so they can fix the senser or what ever is casing it to do that.
Posted on Jul 07, 2009
SOURCE:
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
Paper keeps jamming on Samsung CLX-3160 FN. How do I prevent this from happening?
Paper jams are typically caused by the rubber rollers inability to put paper through the machine. Try cleaning the roller with damp rag to see if that improves performance. If the roller is badly worn, it will need to be replaced.
Oct 04, 2010 | Samsung CLX 3160fn All-In-One Printer
Non-working printer; no paper pickup
The solution shown for the Samsung CLX-3160FN All-In-One works also for the Samsung CLX-2160N.
The associated picture and methodology of "pre-stretching" the solenoid spring is virtually identical for both printers.
Worked for me on the CLX-2160N
See here
http://www.fixya.com/support/t4742967-deve_home_sensor_error
Jul 07, 2010 | Samsung CLX-2160N All-In-One Printer
I have a Samsung CLX-3160FN, and after every page
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
May 15, 2010 | Samsung CLX-3160 All-In-One Laser Printer
CLX-3160FN Paper Jam when there is no paper jam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Keeps jamming
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Oct 09, 2008 | Samsung CLX 3160fn All-In-One Printer
Constant Paper Jam
One of the paper path sensors is damaged, or stuck. Take it to an Authorized Service Center, for two of the 4 paper sensors cannot be reached without disarming the unit.
Be blessed.
Sep 09, 2008 | Samsung CLX 3160fn All-In-One Printer
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
325 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
