TASK SCHEDULER
SOURCE: i cannot copy files
I used to get this problem until i updated my USB drivers. Or try a different USB port. I only have USB 1.1 and this device is 2.0. They should be inter-compatible but you know how these things are sometimes. Make sure the temp of the drive is reasonable too, I've not had heat problems with this one but i have with other external drives in the past.
Hope something I've said helps.
Same error occured for me also so i am using Long Path Tool for copy paste files and folders.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
