Honda 2006 Pilot EX-L Logo
Posted on Feb 14, 2015
How do I fix the problem with my 2006 Honda Pilot EX locks. The locks open with the remote or key, but do not lock with either the remote or door switch. When using the remote to try to lock the doo
Replaced a hard to manually push drivers side actuator to no avail. Checked fuses. Disconnected battery to let system reset.
Driver door lock won't respond to remote, but key in lock won't turn either. Would both be fixed with a new actuator?
More likely, there something frozen or broken in the mechanism you can fix. If the lock mechanism is frozen, a new actuator won't fix anything.
2006 Honda Pilot EX power locks wont lock. Open fine.
Locks are jammed or need lube,,, moved door hinges might have cause the problem
1helpful
How do i fix remote system of Honda City 2006 when remote doesn't open door after replacing batteries?
You should nd to insert ur key in your ignition turn on but do not start the vehicle and hit lock and unlock on controller
1helpful
Programming a honda transponder key
did some quick research for you and found this easy and very clear step by step instructions on how to program your transponder car key to your vehicle.. this works for the following models though :
Accord 2003 to 2006
Civic 1999 to 2006
Element 2003 to 2006
Odyssey 1999 to 2006
Prelude1999 to 2001
Accord SE 1997
CR-V 1998 to 2006
Insight 2000 to 2006
Pilot 2002 to 2006
now here are the steps:
  1. Turn the ignition on
  2. Press Lock/Unlock within 4 seconds
  3. Turn ignition off and hen back on within 8 seconds
  4. Repeat steps 2-3 two times
  5. Press Lock/Unlock again within 4 seconds. The system should now lock and unlock the vehicle to indicate it is in programming mode.
  6. In the next 10 seconds: press Lock/Unlock button allowing the doors to lock/unlock once; then press lock/unlock button of each remaining key, allowing the doors to lock/unlock once.
  7. Switch ignition off and then remove the key
Civic 1996-1998
  1. Turn ignition on
  2. Press and hold the valet button which is situated on the radio within 5 seconds.
  3. System should now lock and unlock the vehicle indicating it is in the programming mode
  4. Within 5 seconds turn ignition OFF and press Lock/unlock on the remote fob to be programmed
  5. Within the next 10 seconds, press Lock or Unlock of any remaining keys, allowing the doors o lock or unlock once.
  6. Release valet key
Radio remotes 2 and 3 button types
  1. Switch ignition on and repeat for 3 times.
  2. Press he lock button, switch the ignition off and back on and then press lock button again.
  3. System should now lock or unlock
  4. Press the lock button of all remotes to be coded. The car should acknowledge this by locking/unlocking each time
  5. Switch ignition off to exit the programming mode.
If you will have any further doubts or question to ask i suggest you to check out the page where i found this which is http://www.carkeyadvice.com/step-by-step-fob-programming-guides/honda :) i hope this was the solution you were looking for mate! happy happy new year!
1helpful
2answers
2003 Honda pilot door locks and remote not working
There is a small electric motor inside the actuator assembly that has probably "burned out". Same problem with my 03 pilot. The remote would not lock the other doors or arm the security system unless you physically locked the driver's side door. Eventually my passenger side burned out as well. Fixed it myself pretty easily. Cheap fix too. works like new now. http://www.ebay.com/itm/120935451126?var=420082237231&ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
2answers
I have a 2006 Honda CRV. The remote locks all the doors except the tailgate. I cannot lock the tailgate with the remote or with the key. Can you tell me what's wrong?
well 2006 crv had many issues. thats why i went for the brand new 2011 honda cr v ex but even this model seem to have its share of hiccups. anyways i think u need to get ur remote unlocked at a dealer.
1helpful
2003 Honda Pilot Door locks not working
may be a relay switch, or a faulty wire on the right side behind the glove box
2helpful
2answers
2003 Honda Pilot - driver's door lock stuck
Mine got 2 rear door stuck. No respond to master switches nor remote.
Top Honda Heating & Cooling Experts
Paul Carew
john h
Are you a Honda Heating and Cooling Expert? Answer questions, earn points and help others
