Washing Machines Logo
A
Anonymous Posted on Feb 13, 2015
Samsung Front Loader WF218ANB error code FL (failure to lock door) but door is locked and will not unlock.
Used to happen only on Sanitize cycle. Now occurs on all cycles. Unlocking the door takes time - it will just unlock after a few minutes to hour. I've tried unplugging; changing cycle, etc. Does not unlock door.
tom cassidy
Level 3:
Genius:
  • Samsung Master 1,585 Answers
  • Posted on Feb 14, 2015
tom cassidy
Samsung Master
Level 3:
Genius:
Answers
1585
Questions
Helped
323043
Points
3520
Change door interlock
1helpful
Fl error code
The "FL" code indicates that the unit failed to lock the door, which would prevent the machine from running. If this happens again, close the door tightly and restart the cycle. If the code reappears, your washer may require service. What is the model number?
Samsung WF337 Door will not opn FL
The "FL" code indicates that the washer failed to lock the door, which would prevent the machine from running. If this happens again, close the door tightly and restart the cycle.
Samsung WF350ANR/XAA has an error code FL and door will not lock to start cycle
The FL Code means that the door failed to lock. Turn the machine off and restart the cycle. If this does not clear the error message and the machine does not return to normal, you will need to contact a Samsung repair service.
1helpful
I'm getting error code FL when trying to start my washer. It will start to fill with water and then error. Please help! It seems like the door is locked.
Hi
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code. It has happened because Door lock mechanism is broken or removed from door. It may also happen due to Door switch/lock unit failure. To resolve the issue follow these steps---
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Hope this helps...Please post back if you need more information.
Daniel
3helpful
2answers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Need to read owners manual for samsung wf218an washer
WF218ANB: http://www.samsung.com/us/support/downloads/WF218ANB
WF218ANB/XAC: http://www.samsung.com/us/support/downloads/WF218ANB/XAC
WF218ANW: http://www.samsung.com/us/support/downloads/WF218ANW
Whirlpool duet - door will not lock. Was working fine and now when I press start, I get the code "FL"and then "d" flashing.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
My front loader washer whirlpool codes fdu and the door won't unlock.
F/dU error means --------- Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error. -------- to resolve the error --------- Door Lock Mechanism broken. globul1a.gif Check Door Lock/Switch Assembly for foreign objects globul1a.gif Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
Dl error message on front loader
This is the info from the error code for your washer DL/F
Door Unlock Error
Potential Causes
• Door Lock Mechanism broken.
• Check Door Lock/Switch Assembly for foreign objects
• Check Wire Harness connections to the Door Lock/Switch Assembly and Central
Control Unit (CCU)
Note: The Door Lock/Switch Assembly can be manually unlocked. See Section
Seven, TECH TIPS
Top Samsung Washing Machines Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
